Want to Sell Intel Q6600 3.8GHz Stable, Asus Mobo, Geforce 8800 gtx, HDD, Watercooling
donkon
Everything is in Mint Condition, NO more than 6 months old
CPU:
Intel Core 2 Quad Q6600 Quad Core Processor G0 Stepping LGA775 Clocked at 3.8ghz @ 1.4375v Stable, comes with Stock Fan (brand new never used)
$160
Motherboard:
ASUS P5K Deluxe/WiFi-AP Desktop Board - Intel - Socket 755 - 1333MHz, 1066MHz, 800MHz FSB - 8GB -
More specifications at:
ASUSTeK Computer Inc.
$180
Graphics Card
BFG NVIDIA GeForce 8800 GTX OC2 768MB PCIe
$100
Watercooling & Accessories:
- Thermaltake Kandalf Liquid cooling Case VD4000BWS includes:
Radiator, pump, tubing, compression fittings, coolant, reservoir and
D-Tek Fuzion Cpu Block
-Manual, Packaging
Everything to easily get started
$220
Extras:
Feser One 6ft UV Clear / Blue 1/2 ID 3/4 OD tubing - $5
Feser One Blue UV Coolant Non Conductive - $10
Feser One Pink UV Coolant Non Conductive - $10
Feser One UV Red Dye - $4
I'm in Scar
monkey_mo
Vancouver, BC
Get some pics with your HWC user name in the pictures, do it now before the mods hunt you down.
Where about's is Scar
donkon
Yeah 1 is up, im in the process of taking the other ones and upping them
qaz393
GTA
nice q6600 what voltage was it doing it on? any print screen with stress test?
Sadasius
Ottawa
CPU:
I am confused. How can it be brand new and never used and somehow you know it is stable at 3.8ghz at 1.4375v? Don't mean to start anything just thought that was strange and perhaps a little misleading.
Sadasius
Ottawa
:doh: nevermind....I am retarded! On another note good buy though as the volts required for that OC is better then mine. Took 1.5v for mine to reach that. Sorry donkon!
