Intel Stock heatsink got stuck on the mainboard
appplejack
Toronto
I'm about to take out the intel stock heatsink but one of the bolts of the heat sink got stuck on the mainboard?
What can I do to solve this?
SugarJ
Folding Team
Langley, BC
You've twisted it all the way in the direction of the arrow to release the lock? Give it a good tug, like you're picking up something that weighs 5 pounds. If it still won't come out, take out your mobo and push the pin from the bottom side while pulling on it from the top side.
appplejack
Toronto
Thanks I managed to take it out but touch the back of the board and it made some fingerprint and shiny marks on it. My palm got sweaty while taking it out. Is there anything I should do to clean it?
One thing I noticed while installing the CPU: it made gnawing sound when I closed the latch. I want to know if it's normal.
JD
Toronto, ON
You could clean it with 99% isopropyl alcohol (it's rubbing alcohol but try and get 99%), though I don't think it's going to effect anything.
And the noise when you put the CPU in, should be fine as it is metal on metal touching and it needs to make a tight lock. Not sure if they way you described it is the greatest but it seems okay.
MpG
Kitchener, ON
The grinding noise is likely the CPU shifting slightly as the plate holds it down. As long as the CPU was dropped in properly and not stuck on something, and you didn't hear a *crack*, not an issue.
Andy
Taichung / Toronto
As long as the cpu was seated properly it should be fine. My old cpu and board used to make crunching sounds whenever I closed the latch.
tzetsin
AB
HA! just try getting 99% isopropyl alcohol nowdays... the clerk will look at you like your a monster. I swear that people nowdays think the only reason to have 99% isopropyl alcohol is for a meth lab. There is absolutely NO store in my entire city that will sell it. 70 %, but no 99%.
TopDogZero
Ajax, Ontario
Meth Lab eh, so that's why I can't find 99% should have realized it was something like that.
kzEr
Toronto, ON
I used to work for a paint store so I get it from there...its worth a shot (the 99% that is)
JD
Toronto, ON
lol really? The bottle I have is uber old.
I thought they just kept it behind the counter though but maybe not.
