IRQ not less than equal
Dr_BenD_over
Fallen Folder
Nova Scotia
OK, I give UP on RAID. The drives are the same model number, but they were bought about a month apart and have different versions of firmware. A quick format seems to work, but a regular format immediately comes up bad. :(
Dr_BenD_over
Fallen Folder
Nova Scotia
Not RAID, not SP3, not Cat 8.9. the only other change I made was a BIOS update. I'm going to run some hardware tests and if they come up clean I'll put an older BIOS in.
geovani
New member
BIOS RAID Configuration
The BIOS RAID Configuration menu appears, presenting the following options:
* Array Configuration Utility
* SATASelect Utility
* Disk Utilities
To select an option from this menu, or from any of the menus within the utility, browse with the arrow keys, then press <Enter>. In some cases, selecting an option displays another menu. To return to the previous menu at any time, press <Esc>.
geovani
Dr_BenD_over
Fallen Folder
Nova Scotia
Confirmed, 24hours BSOD free. Probably that new CPU optimization thing for the 45nm CPU's that got added but can't be disabled, a few other people seem to be having some issues with that.
