Issue with new mobo
gimark
Replaced an MSI board that was giving me problems with an Asus M3A78-EM.
When the computer is turned on it will bring up this BSoD. When I hit reset windows will boot up fine. All connections look good. Have not tried anything else yet.
MeDS
Active member
That looks like a RAM problem, check to see that the RAM is securely in the motherboard. Then run memtest. I had a similar error, which was traced back to a single stick of RAM
martin_metal_88
Quebec City
That's the problem. If you are using XP, he can't do a swap like that you will have to re-install the windows. Vista and seven are able to do such a swap but they can fail time to time. Once again mark is fast on the switch;) sorry dude you will lose all your data.
gimark
Thanks for the reply's guys.
This machine has Vista 64-bit not XP. But i will reinstall and see if it fixes. Thanks again :)
