Issue with RTX 2080?
CactusJoe
Hey, i tried googling this but didnt find anything usefull... :(
Im playing games on steam (dota 2, path of exile, etc.) with a rtx 2080. Once in a while the games are freezing. It dosnt look like a fps drop since the steam integrated fps counter dosnt go down. When i play path of exile, the problem is 1000% worse, it happens every few seconds, its unbearable.
I tried lowering the graphics, setting the games to fullscreen and such to no avail. I tried reinstalling the drivers but it didnt work. My windows is up to date. GPU tweak tells me the temps are around 60 degrees on the gpu and i do not see dents in the gpu's clocks. Windows performance manager tell me gpu goes to 80% but cpu is around 70%. I really am clueless at this point.
I read on google that people were having similar problems with the 20XX serie. Altrought, im not 100% it is the problem at this point.
How do you troubleshoot such a problem? What program should i use?
Games are on a nvem ssd, 7900k cpu, 16gb ram.
Bond007
Nova Scotia
Did you check gpu temps? If temperatures are fine I would put my guess on it being drivers. I would do a full uninstall of driver’s, run “display driver uninstalled” to make sure everything is gone, and reinstall the driver.
rjbarker
Courtenay, B.C
As Bond and Kapt said..."clean install" using DDU ....dont just re-install Driver over the Driver thats there....what PSU? .....anything Overclocked? If anything Overclocked revert to stock as well n test..if you have another GPU you can throw in there for testing would be good....if its still borked as the others said...RMA
Dwayne
Courtenay, BC
I play PoE and there are a couple of things you could try. If you are running DX11, try DX9 and see if the problem is still there. Perhaps a common thread is DX11 with the other steam games? Maybe try to remove and reinstall, or repair, the Direct X installation?
Also, check your client UI for the network setting "Lockstep" and try Predictive. A lot of people have had problems with Lockstep as it is trying to do a 1 to 1 info transfer with the server and the client could pause waiting for a response, which causes a freeze and then a speed up.
