Java Client Error - Not sure where to post.
TokeR
Sydney, Australia
I did something to Java in Task manager and now it will not open the client of a game I play called Minecraft.
I was having problems while playing Minecraft (it was freezing every few seconds) So someone told me to try give it a higher priority in Task Manager and try mucking around with how many Cores are enabled to it..
I was also told to try running it in compatibility mode for Windows Vista Service Pack 2.
So I gave it a shot and now it just wont open.. so I guess I did something wrong, but now I don't know how to undo the changes I have made because I cant get to it in task manager because it will not open lol..
It has been a week or more since this happened so I cant just restore to the last time it worked..
Also it creates this error code file on my desktop whenever I try to run it, I noticed it says my OS is Windows Vista SP2 when it's not and I have stopped it from running in compatibility mode so I am not sure why it says that..
Code:
# A fatal error has been detected by the Java Runtime Environment:
#  EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x00000000774ff2d5, pid=5888, tid=1988
# JRE version: 6.0_21-b07
# Java VM: Java HotSpot(TM) 64-Bit Server VM (17.0-b17 mixed mode windows-amd64 )
# Problematic frame:
# C  [ntdll.dll+0x4f2d5]
# If you would like to submit a bug report, please visit:
#   http://java.sun.com/webapps/bugreport/crash.jsp
---------------  T H R E A D  ---------------
Current thread (0x0000000000949000):  JavaThread "main" [_thread_in_Java, id=1988, stack(0x00000000028b0000,0x00000000029b0000)]
siginfo: ExceptionCode=0xc0000005, reading address 0xffffffffffffffff
Registers:
EAX=0x00000000029adf78, EBX=0x0000000000000002, ECX=0x00000000029ae048, EDX=0x00000000029adfb8
ESP=0x00000000029adf68, EBP=0x000007feef7ec8d0, ESI=0x0000000000000020, EDI=0x0000000000000000
EIP=0x00000000774ff2d5, EFLAGS=0x0000000000010202
Top of Stack: (sp=0x00000000029adf68)
0x00000000029adf68:   0000000000000202 00000000774b76e9
0x00000000029adf78:   000007fffffdc000 0000000000000000
0x00000000029adf88:   00000000029ae170 00000000029ae1a0
0x00000000029adf98:   000000006da0b605 0000000000000001
0x00000000029adfa8:   00000000029ae790 00000000029e6f7a
0x00000000029adfb8:   00000000029b0000 00000000029a4000
0x00000000029adfc8:   0000000000000000 00000000029ae790
0x00000000029adfd8:   000000004d51c8a0 000000004d51c850
0x00000000029adfe8:   000000004bb48890 00000000029ae7c0
0x00000000029adff8:   0000000002a42a04 0000000002a42590
0x00000000029ae008:   0000000000000000 00000000001e6e03
0x00000000029ae018:   00000000029ae7c0 00000000029ae810
0x00000000029ae028:   00000000029b5989 00000000029b4e90
0x00000000029ae038:   0000000000000000 00000000029ae870
0x00000000029ae048:   00000000029ae810 00000000029ae810
0x00000000029ae058:   00000000029b5989 00000000029b4e90
Instructions: (pc=0x00000000774ff2d5)
0x00000000774ff2c5:   00 00 4c 89 b1 e8 00 00 00 4c 89 b9 f0 00 00 00
0x00000000774ff2d5:   0f ae 81 00 01 00 00 0f 29 81 a0 01 00 00 0f 29
Stack: [0x00000000028b0000,0x00000000029b0000],  sp=0x00000000029adf68,  free space=3f70000000000000000k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
v  blob 0x00000000029e703f
j  java.util.HashMap.getEntry(Ljava/lang/Object;)Ljava/util/HashMap$Entry;+61
j  java.util.LinkedHashMap.get(Ljava/lang/Object;)Ljava/lang/Object;+2
j  sun.security.util.MemoryCache.get(Ljava/lang/Object;)Ljava/lang/Object;+9
j  sun.security.provider.X509Factory.getFromCache(Lsun/security/util/Cache;[B)Ljava/lang/Object;+11
j  sun.security.provider.X509Factory.intern(Ljava/security/cert/X509Certificate;)Lsun/security/x509/X509CertImpl;+35
j  sun.security.provider.X509Factory.engineGenerateCertificate(Ljava/io/InputStream;)Ljava/security/cert/Certificate;+145
j  java.security.cert.CertificateFactory.generateCertificate(Ljava/io/InputStream;)Ljava/security/cert/Certificate;+5
j  com.sun.crypto.provider.SunJCE.c(Ljava/lang/Class;)Z+33
j  com.sun.crypto.provider.SunJCE.b(Ljava/lang/Class;)Z+9
j  com.sun.crypto.provider.PBEKeyFactory.<init>(Ljava/lang/String;)V+8
j  com.sun.crypto.provider.PBEKeyFactory.<init>(Ljava/lang/String;Lcom/sun/crypto/provider/PBEKeyFactory$1;)V+2
j  com.sun.crypto.provider.PBEKeyFactory$PBEWithMD5AndDES.<init>()V+4
v  ~StubRoutines::call_stub
j  sun.reflect.NativeConstructorAccessorImpl.newInstance0(Ljava/lang/reflect/Constructor;[Ljava/lang/Object;)Ljava/lang/Object;+0
j  sun.reflect.NativeConstructorAccessorImpl.newInstance([Ljava/lang/Object;)Ljava/lang/Object;+72
j  sun.reflect.DelegatingConstructorAccessorImpl.newInstance([Ljava/lang/Object;)Ljava/lang/Object;+5
j  java.lang.reflect.Constructor.newInstance([Ljava/lang/Object;)Ljava/lang/Object;+92
j  java.lang.Class.newInstance0()Ljava/lang/Object;+118
j  java.lang.Class.newInstance()Ljava/lang/Object;+15
j  java.security.Provider$Service.newInstance(Ljava/lang/Object;)Ljava/lang/Object;+151
j  javax.crypto.SecretKeyFactory.a(Ljavax/crypto/SecretKeyFactorySpi;)Ljavax/crypto/SecretKeyFactorySpi;+77
j  javax.crypto.SecretKeyFactory.<init>(Ljava/lang/String;)V+39
j  javax.crypto.SecretKeyFactory.getInstance(Ljava/lang/String;)Ljavax/crypto/SecretKeyFactory;+5
j  net.minecraft.LoginForm.getCipher(ILjava/lang/String;)Ljavax/crypto/Cipher;+38
j  net.minecraft.LoginForm.readUsername()V+17
j  net.minecraft.LoginForm.<init>(Lnet/minecraft/LauncherFrame;)V+160
j  net.minecraft.LauncherFrame.<init>()V+19
j  net.minecraft.LauncherFrame.main([Ljava/lang/String;)V+4
j  net.minecraft.MinecraftLauncher.main([Ljava/lang/String;)V+24
---------------  P R O C E S S  ---------------
Java Threads: ( => current thread )
  0x000000004cf6c800 JavaThread "AWT-Windows" daemon [_thread_in_native, id=4580, stack(0x000000004dd90000,0x000000004de90000)]
  0x000000004d184000 JavaThread "AWT-Shutdown" [_thread_blocked, id=2156, stack(0x000000004dc90000,0x000000004dd90000)]
  0x000000004d183000 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=5348, stack(0x000000004db90000,0x000000004dc90000)]
  0x000000004bbc4000 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=6048, stack(0x000000004cc50000,0x000000004cd50000)]
  0x000000004bbbd800 JavaThread "CompilerThread1" daemon [_thread_blocked, id=4440, stack(0x000000004cb50000,0x000000004cc50000)]
  0x000000004bbb8800 JavaThread "CompilerThread0" daemon [_thread_blocked, id=2568, stack(0x000000004ca50000,0x000000004cb50000)]
  0x000000004bbb5800 JavaThread "Attach Listener" daemon [_thread_blocked, id=5124, stack(0x000000004c950000,0x000000004ca50000)]
  0x000000004bbb4800 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=4796, stack(0x000000004c850000,0x000000004c950000)]
  0x000000004bb30800 JavaThread "Finalizer" daemon [_thread_blocked, id=4040, stack(0x000000004c750000,0x000000004c850000)]
  0x000000004bb30000 JavaThread "Reference Handler" daemon [_thread_blocked, id=4192, stack(0x000000004c650000,0x000000004c750000)]
=>0x0000000000949000 JavaThread "main" [_thread_in_Java, id=1988, stack(0x00000000028b0000,0x00000000029b0000)]
Other Threads:
  0x000000004bb24800 VMThread [stack: 0x000000004c550000,0x000000004c650000] [id=5284]
  0x000000004bbd3000 WatcherThread [stack: 0x000000004cd50000,0x000000004ce50000] [id=5340]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
 PSYoungGen      total 152896K, used 18366K [0x0000000035860000, 0x0000000040300000, 0x000000004adb0000)
  eden space 131072K, 14% used [0x0000000035860000,0x0000000036a4fa00,0x000000003d860000)
  from space 21824K, 0% used [0x000000003edb0000,0x000000003edb0000,0x0000000040300000)
  to   space 21824K, 0% used [0x000000003d860000,0x000000003d860000,0x000000003edb0000)
 PSOldGen        total 349568K, used 0K [0x000000000adb0000, 0x0000000020310000, 0x0000000035860000)
  object space 349568K, 0% used [0x000000000adb0000,0x000000000adb0000,0x0000000020310000)
 PSPermGen       total 21248K, used 9163K [0x00000000059b0000, 0x0000000006e70000, 0x000000000adb0000)
  object space 21248K, 43% used [0x00000000059b0000,0x00000000062a2fa0,0x0000000006e70000)
Dynamic libraries:
0x0000000000400000 - 0x000000000042e000 	C:\Program Files\Java\jre6\bin\javaw.exe
0x00000000774b0000 - 0x000000007765b000 	C:\Windows\SYSTEM32\ntdll.dll
0x0000000077290000 - 0x00000000773af000 	C:\Windows\system32\kernel32.dll
0x000007fefd770000 - 0x000007fefd7db000 	C:\Windows\system32\KERNELBASE.dll
0x000007fefe3c0000 - 0x000007fefe49b000 	C:\Windows\system32\ADVAPI32.dll
0x000007fefd930000 - 0x000007fefd9cf000 	C:\Windows\system32\msvcrt.dll
0x000007feff560000 - 0x000007feff57f000 	C:\Windows\SYSTEM32\sechost.dll
0x000007fefd800000 - 0x000007fefd92e000 	C:\Windows\system32\RPCRT4.dll
0x00000000773b0000 - 0x00000000774aa000 	C:\Windows\system32\USER32.dll
0x000007fefd9d0000 - 0x000007fefda37000 	C:\Windows\system32\GDI32.dll
0x000007feff550000 - 0x000007feff55e000 	C:\Windows\system32\LPK.dll
0x000007fefe620000 - 0x000007fefe6ea000 	C:\Windows\system32\USP10.dll
0x000007fefd2e0000 - 0x000007fefd337000 	C:\Windows\system32\apphelp.dll
0x000007fef1b50000 - 0x000007fef1baa000 	C:\Windows\AppPatch\AppPatch64\AcLayers.DLL
0x000007fef6170000 - 0x000007fef61e0000 	C:\Windows\system32\WINSPOOL.DRV
0x000007fef8da0000 - 0x000007fef8db8000 	C:\Windows\system32\MPR.dll
0x000007feef4b0000 - 0x000007feef917000 	C:\Windows\AppPatch\AppPatch64\AcXtrnal.DLL
0x000007fef4390000 - 0x000007fef43e1000 	C:\Windows\AppPatch\AppPatch64\AcGenral.DLL
0x000007fefd2b0000 - 0x000007fefd2d5000 	C:\Windows\system32\SspiCli.dll
0x000007fefde20000 - 0x000007fefde91000 	C:\Windows\system32\SHLWAPI.dll
0x000007fefdb20000 - 0x000007fefdd22000 	C:\Windows\system32\ole32.dll
0x000007fefe6f0000 - 0x000007feff476000 	C:\Windows\system32\SHELL32.dll
0x0000000073960000 - 0x0000000073963000 	C:\Windows\system32\sfc.dll
0x000007fefa080000 - 0x000007fefa090000 	C:\Windows\system32\sfc_os.DLL
0x000007fefc760000 - 0x000007fefc77e000 	C:\Windows\system32\USERENV.dll
0x000007fefd410000 - 0x000007fefd41f000 	C:\Windows\system32\profapi.dll
0x000007fefb7b0000 - 0x000007fefb7c8000 	C:\Windows\system32\dwmapi.dll
0x000007feff520000 - 0x000007feff54e000 	C:\Windows\system32\IMM32.DLL
0x000007feff580000 - 0x000007feff689000 	C:\Windows\system32\MSCTF.dll
0x000000006d7f0000 - 0x000000006dec1000 	C:\Program Files\Java\jre6\bin\server\jvm.dll
0x000007fefae40000 - 0x000007fefae7b000 	C:\Windows\system32\WINMM.dll
0x000000006d760000 - 0x000000006d76e000 	C:\Program Files\Java\jre6\bin\verify.dll
0x000000006d3b0000 - 0x000000006d3d7000 	C:\Program Files\Java\jre6\bin\java.dll
0x000000006d310000 - 0x000000006d31a000 	C:\Program Files\Java\jre6\bin\hpi.dll
0x0000000077670000 - 0x0000000077677000 	C:\Windows\system32\PSAPI.DLL
0x000000006d7b0000 - 0x000000006d7c2000 	C:\Program Files\Java\jre6\bin\zip.dll
0x000000006d000000 - 0x000000006d1c3000 	C:\Program Files\Java\jre6\bin\awt.dll
0x000007fefbed0000 - 0x000007fefc0c4000 	C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7600.16661_none_fa62ad231704eab7\COMCTL32.dll
0x000007fefbb90000 - 0x000007fefbbe6000 	C:\Windows\system32\uxtheme.dll
0x000000006d2a0000 - 0x000000006d30b000 	C:\Program Files\Java\jre6\bin\fontmanager.dll
0x000007fefd340000 - 0x000007fefd34f000 	C:\Windows\system32\CRYPTBASE.dll
0x000007feef2b0000 - 0x000007feef4af000 	C:\Windows\system32\d3d9.dll
0x000007fefc560000 - 0x000007fefc56c000 	C:\Windows\system32\VERSION.dll
0x000007fefb400000 - 0x000007fefb407000 	C:\Windows\system32\d3d8thk.dll
0x000007feee6b0000 - 0x000007feef2a4000 	C:\Windows\system32\nvd3dumx.dll
0x000007fefbdf0000 - 0x000007fefbe1c000 	C:\Windows\system32\powrprof.dll
0x000007fefdf80000 - 0x000007fefe157000 	C:\Windows\system32\SETUPAPI.dll
0x000007fefd730000 - 0x000007fefd766000 	C:\Windows\system32\CFGMGR32.dll
0x000007fefda40000 - 0x000007fefdb17000 	C:\Windows\system32\OLEAUT32.dll
0x000007fefd4c0000 - 0x000007fefd4da000 	C:\Windows\system32\DEVOBJ.dll
0x000007fefcce0000 - 0x000007fefccf7000 	C:\Windows\system32\CRYPTSP.dll
0x000007fefc9e0000 - 0x000007fefca27000 	C:\Windows\system32\rsaenh.dll
0x000000006d600000 - 0x000000006d617000 	C:\Program Files\Java\jre6\bin\net.dll
0x000007fefdea0000 - 0x000007fefdeed000 	C:\Windows\system32\WS2_32.dll
0x000007fefdf70000 - 0x000007fefdf78000 	C:\Windows\system32\NSI.dll
0x000007fefcc80000 - 0x000007fefccd4000 	C:\Windows\system32\mswsock.dll
0x000007fefcc70000 - 0x000007fefcc77000 	C:\Windows\System32\wship6.dll
0x000007fefb240000 - 0x000007fefb255000 	C:\Windows\system32\NLAapi.dll
0x000007fefcb00000 - 0x000007fefcb5b000 	C:\Windows\system32\DNSAPI.dll
0x000007fefa790000 - 0x000007fefa79b000 	C:\Windows\System32\winrnr.dll
0x000007fefa770000 - 0x000007fefa785000 	C:\Windows\system32\napinsp.dll
0x000007fefa750000 - 0x000007fefa769000 	C:\Windows\system32\pnrpnsp.dll
0x000007fefa740000 - 0x000007fefa750000 	C:\Windows\system32\wshbth.dll
0x0000000073270000 - 0x00000000732a5000 	C:\Program Files\Bonjour\mdnsNSP.dll
0x000007fefadf0000 - 0x000007fefae17000 	C:\Windows\system32\Iphlpapi.DLL
0x000007fefade0000 - 0x000007fefadeb000 	C:\Windows\system32\WINNSI.DLL
0x000007fefc630000 - 0x000007fefc637000 	C:\Windows\System32\wshtcpip.dll
0x000007fef85c0000 - 0x000007fef85c8000 	C:\Windows\system32\rasadhlp.dll
0x000007fefaca0000 - 0x000007fefacf3000 	C:\Windows\System32\fwpuclnt.dll
VM Arguments:
jvm_args: -Xms512m -Xmx1024m
java_command: C:\Users\James\Desktop\Minecraft.exe
Launcher Type: SUN_STANDARD
Environment Variables:
CLASSPATH=.;C:\Program Files (x86)\Java\jre6\lib\ext\QTJava.zip
PATH=C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\Intel\DMIX;C:\Program Files (x86)\QuickTime\QTSystem\;C:\Program Files\Java\jre6\bin
USERNAME=James
OS=Windows_NT
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 26 Stepping 5, GenuineIntel
---------------  S Y S T E M  ---------------
OS: Windows Vista Build 6002 Service Pack 2
CPU:total 8 (8 cores per cpu, 2 threads per core) family 6 model 26 stepping 5, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, ht
Memory: 4k page, physical 6282356k(3864916k free), swap 12562812k(8912684k free)
vm_info: Java HotSpot(TM) 64-Bit Server VM (17.0-b17) for windows-amd64 JRE (1.6.0_21-b07), built on Jul 17 2010 01:05:36 by "java_re" with MS VC++ 8.0 (VS2005)
time: Mon Oct 18 23:46:32 2010
elapsed time: 0 seconds
Don't know if that will be helpful or not, but thanks for any help.. Also if you know a place where this kind of java error stuff should be posted to get better responses that would be appreciated as well. :thumb:
TokeR
Sydney, Australia
Yeah re-installing minecraft is really easy to do without losing the maps, it was something to do with Java because re-installing minecraft did nothing.
But I did find a fix, which I will share for anyone with the same kind of problem..
I had to un-install Java but you need to wipe with CCleaner after, I am not sure why but after I re-installed java the first time it did nothing, when I tried again and run CCleaner it worked perfectly.
Thanks for your response mate.
martin_metal_88
Quebec City
Glad that you have find a trick! I don't know why some software still use java...it's so crappy -_- why not to use cobol while your at it:haha: Old programmer will understand:ph34r:
