Kauf's 2nd build
kaufman37
Active member
Canada
i7 Gaming Build $1400 -$1500
This is my 2nd build im looking to build a Mid to high end gaming computer for cheap as possible here is a list of parts that i already have and some im planing to get
CPU: Intel Core i7 920 D0 - $340 OWNED
Motherboard: EVGA X58 SLI LE - $280 OWNED
Case: Cooler Master Haf 932 - $150 OWNED
CPU Cooler: Coolermaster Hyper 212 - $30 PLAN TO BUY
GPU: EVGA GeForce GTX 275 - $200 PLAN TO BUY
PSU: Coolermaster Silent Pro 1000W - $160 PLAN TO BUY
RAM: Patriot Extreme Performance Pgs 6GB 3X2GB DDR3-1333 CL9-9-9-24 -$150 PLAN TO BUY
CD/DVD DRIVE: Liteon IHAS124 24X DVD Writer - $30 OWNED
HARD DRIVE : Western Digital Caviar Green 1TB - $60 OWNED
I wanted to leave lots of room for future upgrades hence the tri sli mobo and 1000w psu
Tell me what you think!.Thanks for Reading!
KeepSix
I would add a BLack HDD or an SSD for the OS etc. I'm running one rig with a Green primary, and it's sluggish. Quiet, but sluggish.
martin_metal_88
Quebec City
If you want some speed drop this HD or use it for storage and install windows on a SSD or a black series WD drive. green are to low for windows purpose.
kaufman37
Active member
Canada
How sluggish do you think the Green is? compared to the Western Digital Caviar Black 1TB
martin_metal_88
Quebec City
always depend. The green have the ability to fall in sleep mode after some time of doing nothing so this can give you up to 10 second wait in some operation. the green also run at lower speed and have more acoustic management compared to the black so somewhat lower. It's a very good data disk instead but wasn't meant to do more.
martin_metal_88
Quebec City
Personally I prefer raid 1 instead of SSD because of space for now. I am a medimu gamer and my game take more then 200GB so I will soon go with 2X in raid striping WD640 Black edition which are pretty fast drive.
kaufman37
Active member
Canada
alright guys thanks for the input i think ill be buying a WD BLACK 1TB and use my green for storage.ill be posting my rig when i get it finished thanks again
