KB4532695 January 28TH WIN10 update fun
On2wheels
613 Ontario
This update seems to have changed some folder permissions on a storage drive, it's giving me the:
. This is the 2nd time this has happened on my new Ryzen build, but I didn't notice until after this update came in tonight.
Bleepingcomputer.com said this update should have fixed some Explorer bugs. Is there a way to permanently give my User full access to every folder or does it have to be done one at a time as I find them?
JD
Toronto, ON
You can set the permission on the drive as a whole, just make sure you dig into the advanced page and tick the "Replace all child object permissions" as well:
Though I'm not sure why a Windows Update would change permissions like that.
