keyboard,mouse,mouse pad,speaker,,what about your chair?
cmhyt
never seen someone talk about thier chair here,,,
no one can use their computer with out their chair(except if he/she is japanese)
any one has a good chair that is worth buying?
this chair is made in china product,its about something less than 200CND,i really want to buy this kind of chair,
if i mail it back,,,it would take allmost duoble the price =_=,
so im just thinking if there is a chair simular to this one at the same price range or lower
does it come with hand cuffs and a bright spot light? :biggrin:
I had a good chair once, so comfortable I fell asleep in it a few times.
I'd still have it if the wife didn't deem it as old.
Now I have one she bought me for x-mas. Unconfortable, adjustments suck.
Total piece of crap. standard response "ya, its nice, I like it" :whistle:
it looks great... i like arm sit position... i hate curve one...
but i dont want more than 100 cdn... i more care about comfortable seat and good arm sit... thats all...
no..but you can add alot of things in this chair,,
seatbelts (work better than handcuffs) you can just lock a person in the chair,,,and she(probably=_=) will never find a way to get out ..until you do all your interrogating XD
spot light? yes,,i see alot of lights with clips that can fit this chair right,,
well,,,this is all from china
point is,,,can you find this kind of chair in canada?
if i could find a chair like that i would throw away my broken cheap IKEA chair. Cheap plastic that cracked if you lean back on it :doh:.
Personally, I use a Herman Miller Aeron chair but that is a bit above your price range.
I have an awesome high end leather executive chair. Worth about $700. Got it from the Baliffs for $50. Businesses are going bankrupt all the time.
The Obus Form computer chair is much like that and they are very comfortable. I'm just using a standard high backed operators task chair but I may soon replace it with an 24/7 extended use chair such as are used in emergency comm centres that are manned all the time - they are VERY comfortable - and the foom doesn't compact or get crumbly over time/use either. Problem is they are pricey $600
=_=,,,never heard of a chair more expensive than a computer,,,
the chair on the top,,,if there was a kind simular like that,,the vaule would raise by *1.5,,,
and that brands most expensive chair is about ¥3500 (witch is about 540 CND)
and its a racing chair for cars,,,
