Kingston HyperX 240GB SSD Review
Status
Not open for further replies.
AkG
There certainly has been a lot activity in the Solid State drive market recently, with every company imaginable trying to be part of the SandForce SF2281 family. Some are banking on price to woo customers, while others are relying on sheer performance or increased longevity due to the use of different NAND. What we haven’t seen yet is a combination of performance and longevity bundled with a host of accessories that are meant to enhance the user experience. That however is exactly what Kingston is aiming for with their newest line of Kingston HyperX SSDs.
This may be the first HyperX branded drive Kingston has released, but it is not their first foray into the solid state arena. They have built a sterling reputation for releasing cutting edge drives with some unique panache. Much like the Kingston SSDNow V40 we reviewed many moons ago, Kingston is taking a proactive approach to wooing enthusiast consumers with this new line. They are offering several versions of the HyperX at different price points which come with or without a full accessory package. The top of the line iteration is the “Upgrade Kit” that comes with a literal cornucopia of accessories, all designed to enhance the end user experience.
With an online price which varies from an average of $512 for the basic 240GB model to $550 for the upgrade kit, the Kingston HyperX is not exactly an inexpensive drive – great accessories or not. Nonetheless, this premium is actually par for the course for high performance SSDs sporting capacities greater than 120GB.
The HyperX 240GB comes clad in a very distinctive case. With its dark metallic gray bottom, and top clad in a classic Kingston blue background and a large silver “X”, this drive does have what it takes ascetics department.
While we would love to show you the internal architecture the HyperX comes equipped with security torx bolts and we are unable – or at the very least unwilling – to remove these bolts through force. Internally, the drive should have a very similar layout to other Sandforce-based drives with all 16 ICs populated with Intel branded 25NM NAND dual die modules and a single SF2281 controller.
Also helping to make the HyperX stand out is the accessories package which consists of either a 2.5” to 3.5” adapter (standard version) or “Upgrade Kit” version has a 2.5” to 3.5”, a SATA cable, a USB 2.0 enclosure, USB 2.0 cable, a multipurpose screwdriver and even a copy of Acronis HD migration software for transferring your OS.
By itself, this upgrade kit would certainly be unique in a sea of sameness (most competitors only include a simple adapter plate), but what really sets the Kingston HyperX apart is the NAND used within it. In the past we have looked 25nm Micron branded ONFi 1 and 2 NAND modules and even 32nm Toshiba DDR Toggle Model 1 NAND. This is however the first we have seen of Intel’s 25nm NAND used outside of an Intel branded drive. Unlike most 25nm NAND this NAND is rated for 5,000 erase cycles and not the typical 3,000 found in other devices; giving it a theoretical 40% increase in life span.
AkG
Introducing the SandForce SF2000 Family
As you are probably well aware by now, there are actually many different models which make up the next generation of SandForce controllers. Much like Intel’s socket 1155 i3/i5/i7 series of processors, all these different SandForce numbers represent slightly different tweaks and features, but all are basically built upon the same SF2000 foundation.
In grand total there are eight SF2000 iterations, but for the most part we won't see most of them in the retail channel. Take for example the SF2141; this is a cut down 4 channel, 24bit RS ECC, SATA 3GB/s controller which probably wont see much fan fare outside of truly budget SSDs. The easiest way to think about this one is to consider it the low end of SF2000 drives. Stepping up a level to 8 channels (and 55bit BCH ECC) but still SATA 3GB/s only is the SF2181 which you can consider the mid range of this generation. This one will probably be featured in more mid-tier next generation SSDs as it has better error correction abilities, yet cannot directly compete with the true stars of the SF200 consumer line: the SF 2281.
The only difference between the two “real” consumer grade SF2000 SATA 6G controllers most likely to be seen (the SF2281 and SF2282) is the one -the 2282- is only for extra large 512GB and higher drives (though the SF2281 can handle 512GB of NAND) and is a larger chip. These are the two flagship products as such have received all the features and all the tweaks which are going to become synonymous with the SF2000 consumer class controllers.
The other four controllers are for enterprise environments and boast features such as eMLC compatibility, Military Erase, SAS and super capacitor capabilities.
Features
The SF2000 controller series is built upon the same architecture as the original SF1000 series. You get DuraWrite, RAISE and all the other features but these have all undergone enhancements and tweaking.
The original SF1000 series had ECC of 24bits per 512byte sector of ECC; whereas the new controller has 55bits. The type of ECC has changed as well. The original used the more simplistic Reed-Solomon (aka “RS”) ECC code which is probably best known from its use in CDs.
Compare and contrast this with the fact that the new controller uses Bose-Chaudhuri-Hocquenghem (aka “BCH”) for its ECC code; which is a more elegant version that targets individual errors. It is also faster and easier for the controller to correct these errors making for a lowered performance impact. AES encryption has also doubled from 128 to 256
The most important of these new features for consumers is of course the new SATA 6Gb/s capabilities. This larger bus instantly translates into much higher sequential performance. The second generation of flagship SandForce controllers has also received a boost on the small file performance end of things thanks in no small part to a 20% increase in IOPS. The first generation SF1200 was rated for up to 50,000 IOPS whereas the new controller family has a rating of 60,000 IOPS.
The other interesting feature which all but the most basic of the SF2000 models boast is SLC NAND abilities. In the past, a manufacturer had to step up the enterprise SF1500 to get SLC compatibility but now they don't have to. Add in lowered power consumption and you can see that while the SF2000 series builds upon the same basic foundation as the previous generation, they are not all that similar when you take a closer look.
AkG
A Look at DuraWrite, RAISE and More
Let’s start with the white elephant in the room and explain why this 240GB drive is in reality a 256GB drive. The Kingston HyperX has sixteen 16GB NAND chips onboard which gives it a capacity of 256GB, but is seen by the OS as 240GB. Manufacturers use this to help increase IOPS performance and also extend life via wear leveling (as there are always free cells even when the drive is reported as “full”) and even durability since the drive has cells in reserve it can reassign sectors to as the “older” cells die. While 16GB worth of cells set aside for a SandForce drive is not that much compared to some previous models, this is still a lot of space.
As we said, over-provisioning is usually for wear leveling and ITGC as it gives the controller extra cells to work with for keeping all the cells at about the same level of wear. However, this is actually not the main reason SandForce sets aside so much. Wear leveling is at best a secondary reason or even just a “bonus” as this over-provisioning is mainly for the Durawrite and RAISE technology.
Unlike other solid state drives which do not compress the data that is written to them, the SandForce controller does real time loss-less compression. The upside to this is not only smaller lookup tables (and thus no need for off chip cache) but also means less writes will occur to the cells. Lowering how much data is written means that less cells have to be used to perform a given task and this should also result in longer life and even fewer controller cycles being taken up with internal house cleaning (via TRIM or ITGC).
Longevity may be a nice side effect but the real purpose of this compression is so the controller has to use fewer cells to store a given amount of data and thus has to read from fewer cells than any other drive out there (SandForce claims only .5x is written on average). The benefit to this is even at the NAND level storage itself is the bottleneck for any controller and no matter how fast the NAND is, the controller is faster. Cycles are wasted in waiting for data retrieval and if you can reduce the number of cycles wasted, the faster an SSD will be.
Compressing data and thus hopefully getting a nice little speed boost is all well and fine but as anyone who has ever lost data to corruption in a compressed file knows, reliability is much more important. Compressing data means that any potential loss to a bad or dying cell (or cells) will be magnified on these drives so SandForce needed to ensure that the data was kept as secure as possible. While all drives use ECC, to further ensure data protection SandForce implemented another layer of security.
Data protection is where RAISE (Redundant Array of Independent Silicon Elements) comes into the equation. All modern SSDs use various error correction concepts such as ECC. This is because as with any mass produced item there are going to be bad cells while even good cells are going to die off as time goes by. Yet data cannot be lost or the end user’s experience will go from positive to negative. SandForce likes to compare RAISE to that of RAID 5, but unlike RAID 5 which uses a parity stripe, RAISE does not. SandForce does not explicitly say how it does what it does, but what they do say is on top of ECC, redundant data is striped across the array. However, since it is NOT parity data there is no added overheard incurred by calculating the parity stripe.
According to SandForce’s documentation, not only individual bits or even pages of data can be recovered but entire BLOCKS of data can be as well. So if a cell dies or passes on bad data, the controller can compensate, pass on GOOD data, mark the cell as defective and if necessary swap out the entire block for a spare from the over-provisioning area. As we said, SandForce does not get into the nitty-gritty details of how DuraWrite or RAISE works, but the fact that it CAN do all this means that it most likely is writing a hash table along with the data.
SandForce is so sure of their controller abilities that they state the chances of data corruption are not only lower than that of other manufactures’ drives, but actually approaches ZERO chance of data corruption. This is a very bold statement, but only time will tell if their estimates are correct. In the mean time, we are willing to give the benefit of the doubt and say that at the very least data corruption is as unlikely with one of these products as it is on any modern MLC drive.
AkG
Testing Methodology
Testing Methodology
Testing a drive is not as simple as putting together a bunch of files, dragging them onto folder on the drive in Windows and using a stopwatch to time how long the transfer takes. Rather, there are factors such as read / write speed and data burst speed to take into account. There is also the SATA controller on your motherboard and how well it works with SSDs & HDDs to think about as well. For best results you really need a dedicated hardware RAID controller w/ dedicated RAM for drives to shine. Unfortunately, most people do not have the time, inclination or monetary funds to do this. For this reason our testbed will be a more standard motherboard with no mods or high end gear added to it. This is to help replicate what you the end user’s experience will be like.
Even when the hardware issues are taken care of the software itself will have a negative or positive impact on the results. As with the hardware end of things, to obtain the absolute best results you do need to tweak your OS setup; however, just like with the hardware solution most people are not going to do this. For this reason our standard OS setup is used. However, except for the Vista load test times we have done our best to eliminate this issue by having the drive tested as a secondary drive. With the main drive being a Phoneix Pro 120GB Solid State Drive.
For synthetic tests we used a combination of ATTO Disk Benchmark, HDTach, HD Tune, Crystal Disk Benchmark, IOMeter, AS-SSD and PCMark Vanatage.
For real world benchmarks we timed how long a single 10GB rar file took to copy to and then from the devices. We also used 10gb of small files (from 100kb to 200MB) with a total 12,000 files in 400 subfolders.
For all testing a Asus P8P67 Deluxe motherboard was used, running Windows 7 64bit Ultimate edition (or Vista for boot time test). All drives were tested using AHCI mode using Intel RST 10 drivers.
All tests were run 4 times and average results are represented.
In between each test suite runs (with the exception being IOMeter which was done after every run) the drives are cleaned with either HDDerase, SaniErase or OCZ SSDToolbox and then quick formatted to make sure that they were in optimum condition for the next test suite.
Processor: Core i5 2400
Motherboard: Asus P8P67 Deluxe
Memory: 8GB Mushkin DDR3 1300
Graphics card: Asus 5550 passive
Hard Drive: 1x Seagate 3TB XT, OCZ 120GB RevoDrive
Power Supply: XFX 850
SSD FIRMWARE (unless otherwise noted):
OCZ Vertex 2 100GB: 1.33
OCZ Vertex 3 240GB: 2.09
OCZ Vertex 3 MI 240GB: 2.09
Crucial C300 128GB: 006
Corsair Force 3 GT 120GB: 1.2
Corsair Force 3 120GB: 1.2
Patriot Pyro 120GB: 3.1.9
Corsair Performance 3 256GB: 1.1
Patriot Wildfire 120GB: 3.1.9
Kingston HyperX: 3.2.0
AkG
Read Bandwidth / Write Performance
Read Bandwidth
For this benchmark, HDTach was used. It shows the potential read speed which you are likely to experience with these hard drives. The long test was run to give a slightly more accurate picture. We don’t put much stock in Burst speed readings and thus we no longer included it. The most important number is the Average Speed number. This number will tell you what to expect from a given drive in normal, day to day operations. The higher the average the faster your entire system will seem.
With an average read speed of over 511MB/s the Kingston HyperX 240GB is certainly fast. It may be slightly slower than our Vertex 3 240GB sample was, but a difference of 0.9MB/s is less than 2 tenths of a percentage difference and well within our margin of error.
Write Performance
For this benchmark HD Tune Pro was used. To run the write benchmark on a drive, you must first remove all partitions from that drive and then and only then will it allow you to run this test. Unlike some other benchmarking utilities the HD Tune Pro writes across the full area of the drive, thus it easily shows any weakness a drive may have.
Unlike the average sequential read numbers the HyperX posted, the sequential write performance is actually slightly better than a Vertex 3 240GB. The difference is once again minor enough to be negligible – and well within error ratios. For a 25nm NAND based drive, the Kingston HyperX is extremely fast.
AkG
ATTO Disk Benchmark
ATTO Disk Benchmark
The ATTO disk benchmark tests the drives read and write speeds using gradually larger size files. For these tests, the ATTO program was set to run from its smallest to largest value (.5KB to 8192KB) and the total length was set to 256MB. The test program then spits out an extrapolated performance figure in megabytes per second.
As expected the power curve of the Kingston HyperX is phenomenally good. This of course is thanks in no small part to the fact that ATTO plays the SandForce controller’s strengths with its use of easily compressible data.
AkG
Crystal DiskMark / PCMark 7
Crystal DiskMark
Crystal DiskMark is designed to quickly test the performance of your hard drives. Currently, the program allows to measure sequential and random read/write speeds; and allows you to set the number of tests iterations to run. We left the number of tests at 5 and size at 100MB.
Once again we are seeing the Kingston and OCZ 240GB drives trading blows with one being slightly faster than the other in one subtest, and the other being faster in another. Both of these drives' performance is simply phenomenal and while the Toggle Mode NAND still rules the charts, we think the Kingston may in fact have a small performance advantage over the Vertex 3; or at least have a small lead when incompressible data is used.
PCMark 7
While there are numerous suites of tests that make up PCMark 7, only one is pertinent: the HDD Suite. The HDD Suite consists of numerous tests that try and replicate real world drive usage. Everything from how long a simulated virus scan takes to complete, to MS Vista start up time to game load time is tested in these core tests; however we do not consider this anything other than just another suite of synthetic tests. For this reason, while each test is scored individually we have opted to include only the overall score.
With only four points separating the Vertex 3 from the HyperX you can consider this to be a minor difference at best; but for the first time ever we are seeing a 25nm NAND based SF2281 drive break the 5400 points barrier.
AkG
AS-SSD / Access Time
AS-SSD
AS-SSD is designed to quickly test the performance of your drives. Currently, the program allows to measure sequential and small 4K read/write speeds as well as 4K file speed at a queue depth of 64. While its primary goal is to accurately test Solid State Drives, it does equally well on all storage mediums it just takes longer to run each test as each test reads or writes 1GB of data.
Much like Crystal DiskMark, the Kingston HyperX’s performance numbers in this test continue to impress. When it comes to writes at single and deeper queue depths only the mighty Vertex 3 MaxIOPS version is able to outperform it. The read performance is also extremely good, but the Vertex 3 is once again able to edge it out. To be honest though, there is so little difference between the top two that we consider it to be a draw.
Access Time
To obtain an accurate reading on the read and write latency of a given drive, AS-SSD was used for this benchmark. A low number means that the drive’ data can be accessed quickly while a high number means that more time is taken trying to access different parts of the drive.
When you have to go down to nanoseconds (in this case 2 of them…or two thousandth of a millisecond) to see any differences, you really do know that these drives are evenly matched! It seems that 25nm NAND is 25nm NAND when it comes to random access and it doesn’t matter if it is stamped Intel or Micron.
AkG
Anvil Storage Utilities Pro
Much like AS-SSD, Anvil Pro was created to quickly and easily – yet accurately – test your drives. While it is still in the Beta stages it is a versatile and powerful little program. Currently it can test numerous read / write scenarios but two in particular stand out for us: 4K queue depth of 4 and 4K queue depth of 16. A queue depth of four along with 4K sectors can be equated to what most users will experience in an OS scenario while 16 depth will be encountered only by power users and the like. We have also included the 4k queue depth 1 results to help put these two other numbers in their proper perspective. All settings were left in their default states and the test size was set to 1GB.
AkG
IOMETER
IOMETER
IOMeter is heavily weighted towards the server end of things, and since we here at HWC are more End User centric we will be setting and judging the results of IOMeter a little bit differently than most. To test each drive we ran 5 test runs per HDD (1,4,16,64,128 queue depth) each test having 8 parts, each part lasting 10 min w/ an additional 20 second ramp up. The 8 subparts were set to run 100% random, 80% read 20% write; testing 512b, 1k, 2k,4k,8k,16k,3xk,64k size chunks of data. When each test is finished IOMeter spits out a report, in that reports each of the 8 subtests are given a score in I/Os per second. We then take these 8 numbers add them together and divide by 8. This gives us an average score for that particular queue depth that is heavily weighted for single user environments.
As far as we are concerned this seals the deal when it comes to synthetic performance. It really does appear that any performance variation between Intel to Micron NAND modules is well within error tolerances as both the HyperX and Vertex 3 240GB drives have overlapping lines. In other words, most 25nm MLC dual die NAND modules will perform the same which does make the 40% increase in life all the more persuasive an argument in Kingston’s favor.
Status
