Laptop Keyboard and Touchpad NOT working EVEN external NOT working
ShahJahan
Member
Hello.
I have a Dell Vostro 2520 Laptop.
One day the keyboad and touchpad suddenly stopped working. Then suddenly it starts working again. I reformatted the drive and reinstalled Windows 8.1
However, even in the BIOS it was not working correctly so I knew that this was NOT a software error. I still installed Win 8.1 and all the drivers. It didn't work.
Now thinking that the hardware must be damaged, I used an external keyboard and mouse from my desktop PC (which had previously worked with this same laptop) but to my surprise even that was NOT working and giving the same problems! Like sometimes it works, sometimes it doesn't.
If I press certain keys, like Win key or click then it stops working, when I click all the function (F1, F2, etc) keys then sometimes it starts working again, but only for a few seconds.
Thinking that this is NOT a software problem NOR a hardware problem, I updated the BIOS, but the problem still persists! Its NOT the OS, Driver, BIOS, Hardware problem since I changed ALL OF THAT!
So what is this?!
Thanks in advance for your help!
SKYMTL
HardwareCanuck Review Editor
Montreal
Sounds like a general chipset issue. Remember, even though you might not see it, the keyboard and trackpad are connected to the motherboard's internal headers. That means they are running through the USB bus. If there's an interconnect problem from the USB hub, it will trickle down to the ports AND integrated keyboard / touchpad.
Does your system properly read USB flash drives?
MARSTG
Age
41
Montreal
Indeed if the problem persists while in bios and even with external hardware you are looking at internal hardware failure which would mean replacing the USB hub. It might be worth trying to see if an express card with USB ports would mitigate the issue, if not, you are looking at board replacement which probably will not be worth.
ShahJahan
Member
Hello. Thanks for all your replies.
In order to check if the PCH Board was dying, I checked all the other components of the laptop like USB, Card Reader, WiFi, Ethernet and ALL of them seemed to work flawlessly!
I haven't checked by removing the INTERNAL pin (connector) for the keyboard so will check it later. BTW, is there just one pin/connector for BOTH the keyboard AND the touchpad?!
Also, very strangely the touchpad driver I installed shows using animation on it's taskbar icon whenever I touch the touchpad or click using the left and right touchpad buttons. Strangely, the animation is activated when I touch the touchpad OR it's buttons, (that the touch and clicks are being registered) BUT strangely the system doesn't register that click (no effect in Windows).
The workaround I've found to make the keyboard and touchpad work again is by pressing the Ctrl+Alt+Del button and then press the back button (beside the lock screen option) seems to make it work again, TEMPORARILY.
What should I do next?!
Thanks again for all your replies, I sincerely appreciate it.
ShahJahan
Member
There was NO hardware failure. It had been raining continuously for the last few days NON-STOP, hence the moisture had made it behave that way. The way to fix it (if you too have the same problem) is to open the laptop, clean the RAM sticks with a pencil eraser and dry the entire inside of the laptop using a hair dryer! The hot air blow will remove all the moisture out of it!
Just make sure you first search YouTube for a way to open your laptop so that you don't break anything!
Thanks again all for your help. I sincerely appreciate it!
