Ok, so I have ordered my parts from NCIX (god bless price matching, over 200$ this time before taxes! 10% of the money I spent!) and here is what I have coming to me:
-Corsair HX1000W
-Gigabyte X58A-UD5 ATX LGA1366
-Corsair XMS3 Dominator GT CMD12GX3M6A1600C8 12GB DDR3 6X2GB DDR3-1600 CL8-8-8-24
-Corsair CMXAF2 Dominator Triple Channel Airflow Memory Fan
-Intel Core i7 930
-Corsair Obsidian Series 800D
-Intel X25-V 40GB (currently have one, but now that TRIM is suppored in RAID I'm upping it to two =D )
-Nmedia HTPC-6000B
-Nmedia LCD Module 2X20
The last two are for what I am currently running to throw into a HTPC case
I have a GTX480 on preorder but will be changing it to the eVGA GTX480 FTW version when it is available for preorder. For now I'll be using my GTX260 Core 216!
Anyhow, back to the task at hand! I want a watercooling loop that will (first) go Res>Pump>CPU Waterblock>Rad>Res, like this!
I am just wondering if the pieces I have selected will work, especially the fillport I will be using as a drain port (I've read a lot of the watercooling/builds and it seems like everyone loves to have a drain port!) As well if I should be using compression fittings instead of barbs?
Here is the list!
-Waterblock
DAZMODE LIMITED EDITION HEATKILLER Rev3.0 1366 VERNICKELT Watercool HeatKiller 3.0 LGA 1366, Core i7 [14015-VERNICKELT] - $125.99 : DazMode, Watercooling enthusiasts store
-Rad
Feser One X-360 TFC Xchanger Triple 120MM Water Cooling Radiator G1/4 - DirectCanada
-Pump
Swiftech MCP355 High Performance 12V Industrial Water Cooling Pump 3/8IN Barbs - DirectCanada
-Pumptop
Ek Water Blocks EK-DDC X-TOP Custom Pump Top for DDC or MCP350 or MCP355 Water Cooling Pump G1/4 - DirectCanada
-Res
Ek Water Blocks Ek Multioption Res 250 REV.2 Water Cooling Tube Reservoir G1/4 - DirectCanada
-Tubing
Primochill Primoflex Pro LRT UV Blue 3/8IN ID 5/8IN OD Tubing (10 Feet) - DirectCanada
-Fansx6
NCIX.com - Buy Scythe Ultra Kaze 120MM High Static Pressure Fan 38MM 3000RPM 133.6CFM 45.9DBA - DFS123812H-3000 In Canada.
-Fittings???
Bitspower -TRUE SILVER- G1/4 High Flow 1/2IN Barb Fitting - Silver Plated (Single) - DirectCanada
or
Bitspower BP-CPF-CC5 G1/4 to 1/2IN Straight Compression Fittings -SILVER SHINING- (Pair) - DirectCanada
-Fillport?? (which, again, will be used as a drainport)
Danger Den Cooling System Fillport Black W/ Wrench - DirectCanada
So, I'm guessing I'm on the right track, right? Haha!
A BIGGGG thanks goes out to BigDogg for all the help via PMs he has been giving me along the way!! (I still am contemplating Thermochill or Feser =S)
-Corsair HX1000W
-Intel Core i7 930
-Nmedia HTPC-6000B
Here is the list!
-Waterblock
-Rad
-Pump
-Pumptop
-Res
-Tubing
-Fansx6
-Fittings???
or
