Let's go Team !!
stoanee
Folding Team
Lacombe Alberta
That sucks....what kind of OC you got going? There is a good ~9K ppd in that chip. Small FFTs test mostly the cpu....you really stress the ram yet? Try memtest and large FFTs? Your setup is close to mine, and I got 3.4GHZ first try no probs, and folds no prob too.
I am going for 4 ghz and I think I am there. I uninstalled smp folding & reinstalled and it seems to be working now. I only get 6000 +-ppd though. I am still playing with voltages trying to get temps down. I have a megahalem to install to help me also. I had to set the cpu voltage to 1.3 to get there so as you can imagine it gets a little warm.
chrisk
Folding Captain
GTA, Ontario
That chip would get more than 9000PPD (actually, my 3.4ghz is getting 9000PPD.....) using the vmware client.
stoanee
Folding Team
Lacombe Alberta
Hmmm.... followed the instructions ( 4 instances of notfred) to the letter, I think. Not sure why I get so little ppd.:sad:
chrisk
Folding Captain
GTA, Ontario
Are all your cores running at almost 100% when you get the 4 instances up? Hyperthreading enabled? Did you set each virtual machine to 2 cores?
stoanee
Folding Team
Lacombe Alberta
Yes, yes and yes. I will have another look at it all tomorrow to make sure all is done as good as I can get it, I have to try tweaking priority and affinity but Priffinity does not work the same under Windows 7 as it does in XP. The I7 rig just froze up :doh:, not sure why, but no bsod. I may have to back off on overclock even though it seems to be primestable.:blarg:
chrisk
Folding Captain
GTA, Ontario
One last thing I guess before I forget; what program are you using to monitor the vmware clients? You should be using the latest Fahmon (has an option for virtual machines), or better yet, use Fahspy. Then, make sure that the program you are using has the updated work units (fahmon = 'download new projects', and Fahspy = 'update wu database'. Could be something as simple as the software you have is not reading it right.
Jon_di2
Toronto, Ontario
Well if your in the GTA like me, I'm sure that the heat is killing you and your folding. I have a 12000btu portable air condition sitting right beside my rigs and it can't keep up with the heat. So I'm shutting down until the heat spell is over.
Hope the folders in other cities aren't experiencing this much heat!
chrisk
Folding Captain
GTA, Ontario
Woke up this Am and saw that my i7 rig had rebooted. Error log looks like a hardware issue. It was running 4 vmware, 2 GPU instances, and the temps were 80c+ on the cards, 70c on each core, with a room ambient of 29c (according to the multimeter temp sensor). I'm hoping the heat got to the rig, so I'll give her a break for a few days until the heat dies down.
