Let's go Team !!
LCB001
Aylmer QC.
So have 2 9800GX2's in one machine and I am having a rather hard time getting the 4th client to work. The first three clients are working great but the fourth gets an 'UNSTABLE_MACHINE' before it even tries.
In the shortcut I made for the client I have the target:
And Start in:
Everything looks right to me.
Are you using the systray client because something seems off about the 'Target:' line.
On my systray machine both shortcut target lines are the same except for the -gpu X at the end.
You might also try adding the -local flag if you have not already...
lowfat
Grande Prairie, AB
This is the way I was taught to do it. I just tried keeping the client info and the workunit stuff in one folder and it did the same thing. As well as adding the -local flag.
I rebooted my computer and now neither GPU client on the 2nd card are working :doh:
3.0charlie
Bedford QC
Which OS are you using.
Which Fahcore was downloaded, for Cores 11 and 14.
Did you change the Machine ID for the 4th Client.
I don't remember reading this, but did you extend the monitor for the 4th Client, and did you disable multi-Gpu support.
Delete the core, work folder, and queue.dat.
lowfat
Grande Prairie, AB
Using Win7. Machine ID has been changed. I tried extending the monitor and tried using a dummy plug. And yes Multi GPU support is disabled. And I have tried deleting the core, work folder, and queue a whole bunch.
_dangtx_
mtl
353's and whatever other wu are different between them. screenie of fahmon with full info tabs can show you the difference. run x vs run y can translate into 1kppd difference.
