Let's go Team !!
MarkOne
Chertsey 60 KM north of Montreal
Mine is running ~ 68°C to 77°C with CM212+ push/pull with 2x Noctua NF-S12B FLX. I could get a bit lower temps with the stock fan (or higher oc's) but I like it quiet.
go I gone try to go for 4 ghz with 70'C ( I'm optimist here :ph34r: ) after i will see if I water the CPU , I have already th pump and the rad . only the block is missing ( not too bad )
Arinoth
Halifax
What are your shaders clocked at (how much over stock)? My GT260's aren't getting that high a PPD.
Mine are clocked to 1520 and 1540 respectively. The 1520 is my main gpu (sli disabled) and i find will get anywhere beween 7700 to about 8500 depending on if i'm using the pc or not, the 1540 gets about 8200-9000 ppd
