Let's go Team !!
LCB001
Aylmer QC.
ok, because i started the CPU client, second one on the list of CPU clients here
[email protected] - DownloadWinOther (Windows XP/2003/Vista/2008 SMP client console version 6.22 beta2 for MPICH (32-bit or 64-bit))
and it is just sitting at 0%
Completed 0 out of 5000000 steps (0%)
i just did a fresh install of XP PRO, and have .net 1.1, 2 and 3 installed and had to reboot, going to give it a few minutes and see if it starts working
You should be using the regular CPU client available on the main d/l page [email protected] - Download the [email protected] software application
The P4 probably wouldn't make the deadlines on the SMP client as it's designed for Quads...
Dashock
Toronto
Yea we have all been smacked with these new Wu's thanx LCBOO1 i didnt even notice there was an update to the console im now updated to 6.23 gonna test it tonight hopefully i get somewhere with it. Keep it u guys!
We need more for the fight!.
4DoorGTZ
Calgary, AB
I'm kinda dissapointed at the ppd from my 8 core Xeon.... 2x SMP and 1x ATI GPU, can someone confirm or deny if you have dual vid cards in non sli/crossfire, do you need a monitor connected to each to fold?
4DoorGTZ
Calgary, AB
Been watching the usage and temps, 1smp and 1gpu is about 60% and mid 60c temps (air) adding a second smp takes it up to 100% high 70c and slows down the other smp and gpu clients.... I suppose I could try it, I'm just not able to sit and watch it so I'm trying to first build up the OC to somewhat reliable levels (3.16-->3.55 so far, over 3.6 seems to randomly crash within a day or so) I'm thinking along the lines of 2x2500pps is better then 4x1000ppd, and the later would have poorer gpu ppd as well.
LCB001
Aylmer QC.
If you limit your SMP clients to ~97-98% CPU usage it should leave enough free for the GPU, depending on your O/S...
As 3.0charlie said if you want to run more than one GPU client, you need a monitor for each, or at least a dummy plug. Don't forget to extend your desktop and use the -local flag...
Dashock
Toronto
Alright i dont know if its the new Nvidia drivers or the new core files but im getting raped im down to 3500 ppd on the 5748-5756 i did update to the latest client 2.63 as well.
LCB001
Aylmer QC.
It's the new 511 point WU's, the lower the number of SP's on a card, the bigger the effect on the PPD it seems. Don't feel bad tho it's nailing everybody, my GTX+'s are down from ~6150 ppd to maybe ~4300 ppd with those WU's. You should read some of the whining on other forums, you would think Hell Had frozen over. The guys I feel bad for are the guys running farms with 10 to 15+ GPU's, you think your getting raped, Ouch :sad:. At least the 384pt ones are almost as good as the 480's and actually use the CPU less, my SMP ppd goes up ~100 to 150 ppd.
