Let's go Team !!
_dangtx_
mtl
ok...probably it depends on wu but im getting about the same with a 3.5 gig 2 meg cache quad(630)
over 4k if not heavier use of the machine on this wu, it seems
Project ID: 6041
Core: GRO-A3
Credit: 1395
Frames: 100
Path: E:\Program Files\[email protected] Windows SMP Client V1.0133334\
Number of Frames Observed: 40
Min. Time / Frame : 00:21:58 - 4,506.2 PPD
Avg. Time / Frame : 00:25:17 - 3,649.2 PPD
Cur. Time / Frame : 00:22:07 - 4,163.6 PPD
R3F. Time / Frame : 00:22:15 - 4,138.6 PPD
All Time / Frame : 00:25:13 - 3,651.7 PPD
Eff. Time / Frame : 00:28:38 - 3,216.0 PPD
indeed. my other 2 'old' smp clients dont pick up wus..is this a way to tell us indirectly to switch over? :)
chrisk
Folding Captain
GTA, Ontario
Weird. It seems if you get started on the A3 WUs, you are fine. Last night, I have one smp2 machine getting A3 units straight away, and the other did not.
After I cleared the Work folder, core, quque.dat, it picked up some and has been chugging on them since. Maybe some servers have more WUs than others? There are lots of posts around the net, and foldingforum compaining about the lack of WUs.
Zero82z
Montreal, QC
I'm guessing it just has to do with luck of the draw. It depends on how much work there is at the time your client contacts the assignment server for work, and how many other people are asking for work at the same time.
_dangtx_
mtl
what gets to me is that it doesnt even give the ip of the server, just tells you youre out of luck lol
Zero82z
Montreal, QC
If the assignment server knows that the work servers don't have anything for you, it would be a waste of server time to assign you to an empty work server.
chrisk
Folding Captain
GTA, Ontario
Well then.
One of the smp2s for Bananas just ran out of work for the first time. :doh:
sswilson
Moncton NB
Project ID: 6041
Core: GRO-A3
Credit: 1395
Frames: 100
Keep in mind that my smp clients run at the lowest priority and that my gpu clients take up between 5 - 10% of cpu cycles.
_dangtx_
mtl
ok, that makes sense then.
funny thing is, ppl complain about babysitting gpu clients, hell ive had better luck with them than smp lol
