Let's go Team !!
sswilson
Moncton NB
Most recent update..........
Worst case scenario (2X 6701/6702) still shows a net gain using the -advmethods compared to both non-advmethods on the 450, and my previous PPD on the same setup using the GTX275. SMP2 6701 PPD is around 8.5K vice the aprox. 10.5K PPD running GPU2 with the 275. Combined PPD over all clients in this situation is sitting around 38.5K PPD vice the 34 - 36.5K I was seeing with the GTX 275 installed.​
Definitely an improvement over the 275 while using -advmethods, but I suspect that's only with a single GPU client running, and that the hit to CPU cycles would dramatically decrease PPD on time based CPU clients/WUs (such as SMP2 or Bigadv).​
Temps with the -advmethods WUs are still amazing even though I've dropped the fan speed down to 80%​
CroSsFiRe2009
Toronto, ON
What in holy hell...how is your 450 pulling almost as much ppd as my 470 lol? Has anybody seen ppd numbers for a 470 at 800/1600? I'm only getting 16.5k and I'm pretty sure advmethods is enabled. 18.4k at 925/1850. Not running a cpu client so that shouldn't be affecting anything.
sswilson
Moncton NB
What's your CPU speed running at? I'm inclined to believe the theory (suggested here earlier) that the -advmethod WUs are being partially offloaded to the CPU, and that CPU speed is also coming into play.
With that in mind, I wonder how far it would be to come up with some form of a fully unified client that takes advantage of both the CPU and the GPU?
_dangtx_
mtl
oh man, those words are golden. one ring to rule them all..i mean, one client to master them all. start it up, and use whatever you feel like off your hardware wise.
CroSsFiRe2009
Toronto, ON
It's running bonestock at the moment. It's not using cpu resources but I'll be checking tonight if bumping up qpi or whatever oc I can get while using the stock cooler affects the ppd.
sswilson
Moncton NB
Yet another (and probably final) update on the 450 running -advmethods.
Pulled a "normal" GPU3 WU last night, and realised that the -advmethods + SMP2 (not bigadv) gives the best of both worlds as it provides a "hedge" for lesser performing GPU3 WUs. The PPD for the standard GPU WU went back down to 9.9K, but at the same time, because of the smaller CPU resource requirements it allowed the SMP2 PPD to return back to full output.
-advmethods still puts out the best overall PPD, but the raise in SMP2 PPD has the effect of moderating the difference.
Now, if we could only convince the GPU2 work server to stop bunging up, all would be good in the world. ;)
stoanee
Lacombe Alberta
MSI N460GTX Cyclone 768D5 pulling 12000ppd, bone stock. 44C 55% fan speed, cannot hear it over the case fans. :thumb:
Time to play....
sswilson
Moncton NB
Is anybody else getting GPU3 -advmethod WUs? I started pulling normal ones a day or so ago, and now have switched the 450 over to a different rig so I'd never know if it was running properly.
Even without the -advmethod GPU3 WUs, now putting out aprox. 57K. :)
ilya
Markham
I stopped getting the new WUs last night, had to tone down the O/C since I was getting heat related NANs and EUEs with the normal WUs.
sswilson
Moncton NB
Thanks for the info. Just wanted to make sure it wasn't just me. As far as the heat goes.... my temps only go up about 10c, but I've got my fan pegged to 80%, and the ASUS TOP cooler does a pretty good job.
