Never had a problem gpu folding before, any advice? This is with a MSI GTX460 in my I7 920 that has had no problems in the past. I tried uninstalling the card, drivers and gpu client, no luck.
23:07:04] + Processing work unit
[23:07:04] Core required: FahCore_15.exe
[23:07:04] Core found.
[23:07:04] Working on queue slot 00 [November 8 23:07:04 UTC]
[23:07:04] + Working ...
[23:07:04]
[23:07:04] *------------------------------*
[23:07:04] Folding@Home GPU Core
[23:07:04] Version 2.11 (Fri Nov 5 12:50:40 PDT 2010)
[23:07:04]
[23:07:04] Build host: SimbiosNvdWin7
[23:07:04] Board Type: NVIDIA/CUDA
[23:07:04] Core : x=15
[23:07:04] Window's signal control handler registered.
[23:07:04] Preparing to commence simulation
[23:07:04] - Looking at optimizations...
[23:07:04] DeleteFrameFiles: successfully deleted file=work/wudata_00.ckp
[23:07:04] - Created dyn
[23:07:04] - Files status OK
[23:07:04] sizeof(CORE_PACKET_HDR) = 512 file=<>
[23:07:04] - Expanded 19081 -> 76495 (decompressed 400.8 percent)
[23:07:04] Called DecompressByteArray: compressed_data_size=19081 data_size=76495, decompressed_data_size=76495 diff=0
[23:07:04] - Digital signature verified
[23:07:04]
[23:07:04] Project: 11231 (Run 2, Clone 33, Gen 38)
[23:07:04]
[23:07:04] Assembly optimizations on if available.
[23:07:04] Entering M.D.
[23:07:06] Tpr hash work/wudata_00.tpr: 3238939491 3632519818 218216597 607463388 1599697107
[23:07:06]
[23:07:06] Calling fah_main args: 15 usage=100
[23:07:06] 0 <mdrun_gpu>
[23:07:06] 1 <-v>
[23:07:06] 2 <-quiet>
[23:07:06] 3 <-s>
[23:07:06] 4 <work/wudata_00.tpr>
[23:07:06] 5 <-o>
[23:07:06] 6 <work/wudata_00.trr>
[23:07:06] 7 <-e>
[23:07:06] 8 <work/wudata_00.edr>
[23:07:06] 9 <-c>
[23:07:06] 10 <work/wudata_00.gro>
[23:07:06] 11 <-g>
[23:07:06] 12 <work/wudata_00.log>
[23:07:06] 13 <-x>
[23:07:06] 14 <work/wudata_00.xtc>
[23:07:06]
[23:07:06] Working on 264 Fs_coil
[23:07:06] Client config found, loading data.
[23:07:07] Starting GUI Server
[23:08:07] Completed 1%
[23:09:07] Completed 2%
[23:10:07] Completed 3%
[23:11:07] Completed 4%
[23:12:07] Completed 5%
[23:13:07] Completed 6%
[23:14:07] Completed 7%
[23:15:06] Completed 8%
[23:16:06] Completed 9%
[23:17:06] Completed 10%
[23:18:06] Completed 11%
[23:19:06] Completed 12%
[23:20:06] Completed 13%
[23:21:07] Completed 14%
[23:22:07] Completed 15%
[23:23:07] Completed 16%
[23:24:07] Completed 17%
[23:25:07] Completed 18%
[23:25:07] mdrun_gpu returned 54
[23:25:07] Nonzero force sum on GPU
[23:25:07]
[23:25:07] Folding@home Core Shutdown: UNSTABLE_MACHINE
[23:25:11] CoreStatus = 7A (122)
[23:25:11] Sending work to server
[23:25:11] Project: 11231 (Run 2, Clone 33, Gen 38)
[23:25:11] - Read packet limit of 540015616... Set to 524286976.
[23:25:11] - Error: Could not get length of results file work/wuresults_00.dat
[23:25:11] - Error: Could not read unit 00 file. Removing from queue.
[23:25:11] EUE limit exceeded. Pausing 24 hours.
:angry2:
