Let's go Team !!
Nademon
Toronto
sounds like a good idea. I think I'll try just that. Just hope it's not too much of a task disassembling and reassembling the gx2.
LCB001
Aylmer QC.
I'd second the advice by Soutribunal, I blow out my rigs and clean the filters every two weeks max. If your temps are that high it could definatly be the cause, they sound at least 5-10*'s high and that's all it takes. Changing the TIM can't hurt, and might gain you a couple of degrees.
I've had the suspicion for a while that the GPU temp. sensors don't read accurately when you are just OC'ing the shaders. The key seems to be airflow not just through the case, but directly on the vidcard. If you could get something like a spotcool pointed at the card inlets it might help.
If all that fails you might need a reinstall, just make sure you do a complete uninstall first using something like ccleaner. Sometimes a conflict develops with something like vista or an anti-virus and a new install might fix that. If you reinstall you might try switching to the systray client, it's sometimes makes a difference and is easier with a multi-gpu setup.
This is all presuming you are getting standard EUE's and not something like NAN's, that would be a real pain in the :censored:...
Prof. Dr. Silver
Toronto, ON
Don't worry!
Our 9800 GX2's are just very HOT cards! A while ago I posted a screenie of my temps touching 100C !!! I was worried too and did some research... I saw people taking off the metal casing on their cards and running them butnaked... :shok:
I did just that and saw an drop of 12 degrees after aiming an extra fan on the bare PCB. Right now the shaders are OC'ed to 1678MHz and I'm running the :censored:511's, card 1 does 86C, card 2 does 78C and the PCB is 67C. Too hot for touching but the card runs great. The newer WU's run at 82C and 74C!
As for the EUE's.... I had tons of those as well. That why I quit folding for a bit...cause I had no time to figure out why. Now with the 182.06 drivers and the '-advmethod' I've run a few :censored:511's, 420's and 384's.....and so far (24hours) all went well!
Good Luck and let us know who the taking apart goes...Pics? :punk:
LCB001
Aylmer QC.
Good to see you back Folding, glad you got those problems sorted out...
chrisk
Folding Captain
GTA, Ontario
Just added -advmethods flag before current wus were done...was it ok to do this without deleting the core/current wus?
Soultribunal
Mississauga
I like some stuff from TT, but Chrisk, 3 of those suckers on me have melted. Literally.
I have no idea who designed them, but they need help lol!
Use this to get Air Directly on the Cards.
Vantec Spectrum PCI Fan Card with Blue UV LED SP-FC70-BL in Canada at TigerDirect.ca
If, you ask nice enough, I could send you the one out of the Test Rig that is currently cooling my secondary ATi Card.
:whistle::whistle:
Regards,
ST
