Let's go Team !!
LoTech
Calgary
Currently disappointed w/ the card. It errors out pretty much every WU even @ stock clocks. :angry2:
Wonder if the card has something new in it that [email protected] doesn't recognize? Is it part of the gpus we can use. Meaning is there a list somewhere that states this card can be used to fold with. I was actually thinking of getting one myself so keep us posted. Hears a thought. Why not remove the whole client from the said PC and reinstall. Do you think that may work? I always thought the 780's were just a cut down Titan and they fold fine. Good luck LF.
trodas
Czech republic
Website
trodas.wz.cz
lowfat Classy - It errors out pretty much every WU even @ stock clocks.
Indeed that is pretty much disapointment. However as long, as the card render graphic fine and there is no error, then I would be inclined to presume that something is wrong with either folding client, or the card drivers.
For example if (I did not say it is this way, because I honestly don't know) the card run in 2D mode (is there are lower voltages in 2D after all on this card...?), then one cannot wonder that the GPU cores give a error, because they run undervolted.
Another idea (despite bugging the client programmers) is to use the overclocking bios for the card and push the throtling limits up and see, if that did not help.
The card sould be fine, don't trash her to vohiep84 yust yet :)
lowfat
Grande Prairie, AB
I am pretty confident the issues are w/ the card and not the client. It just isn't completely stable at stock. I've tried up to 1.2V w/ stock clocks and it was erroring out within 5-10 minutes of starting the WU. Going to throw in one of my watercooled cards again and test it w/ more voltage. I have my doubts the Classified is much better.
LoTech
Calgary
That's really weird. I have 6xx series cards and no issues. Maybe you did get a flakey card. I have yet to see problems like that. Mine are usually burnt out fans....sigh on the cards.
lowfat
Grande Prairie, AB
Started to give my GTX780 significantly more voltage. Now folding @ 1254MHz on the core which seems to give be between 180,000 and 200,000 w/ 7810/7811s. That is definitely higher than I could fold w/ the Classified.
EDIT: Taking it higher. :whistle:
LoTech
Calgary
Why is the Lowfat? Is it because there was no more room with the classy? Did you finally sell it?
lowfat
Grande Prairie, AB
When I bought the Classified I was unaware there was a way to increase voltage on reference cards past 1.2V. But now I know how to increase to 1.325V. The Classified was likely limited by temperature but I didn't want to spend another $200 on a block to see how it would do. Ya I sold the card earlier this week.
As for my reference card I am going all out buck wild now. I wonder how well this will hold long term. If the VRMs didn't get active cooling I am sure the board would likely blow up :haha:. Obviously the PPD isn't correct as you know how the 7811s fluctuate. But it does seem to be semi what stable @ this clock speed so far.
EDIT: Of course I take the screen shot when it does one of its dips :doh:. The card is actually running @ 1333MHz right now.
