Let's go Team !!
lowfat
Grande Prairie, AB
If you add the beta flag I think you'll end up w/ less core 15 WUs. Just guessing here though.
And no it isn't on water, not yet anyways.
3.0charlie
Bedford QC
@ 1200MHz my GTX780Ti is doing about 232K PPD. That is about 25K higher than what I could get w/ a GTX780 @ 1372MHz.
Are you kidding me. That single GPU now surpasses what my old 4P (quad 6272s) was capable of, and for a whole lot cheaper. What's the power consumption like?
stoanee
Lacombe Alberta
Loaded Win7 onto my SR2 and started folding with FAH v7. The GTX760 ppd is right where I expect it to be, 25-28,000 ppd, but the cpu is very low 30-35,000. Slider is at full. Seems to me that many moons ago, before I switched to Linux, I was getting 70-75,000ppd from cpu on win7 FAH v7. Am I missing something or should I go back to FAH v6?
MARSTG
Age
41
Montreal
Remember that by default the setting in win 7 are for balanced performance, you need to switch to high performance in the power settings. My setup with 2 hexacores at 3.0 GHz was getting between 60 and 120k PPD, depending on WU. Also the GTX760 should be getting around 60k PPD with the 8900WUs or around 45k PPD on regular units.
LoTech
Calgary
I moved your post to a more relevant thread since it didn't actually have to do with 8018 WUs.
From another thread.
Lowfat, you were bang on. Not sure how it happened but the NVidia drivers had changed on that box. I was running the 331.xx or something. Now back to 327.23 and all is good. Getting about 130K PPD with the 2 660's. Thanks. Not sure if this GeForce experience just updated it for me or what. Other machine is still fine no updated driver there. :ph34r: hmmmm
and by the way THANKS!!!
stoanee
Lacombe Alberta
Yep, slider set to full, running process lasso to keep priorities. Two [email protected] May have to delete and reinstall. I always had better results with v6, may try that again If I cannot get v7 working for me.
akira749
Donnacona, QC
What drivers are you using? If you aren't using a GTX780 or you should be using to 326.80 or older. Anything newer will cripple performance.
You're the man! You just resolve my GTX 770 problems!!!
Downgrading to 326.80 gave me a solid jump in PPD
They were getting 40K for one and 43K for the other on 8900 WU's and now 90K and 93K on the same WU's :clap:
I will do the same on the rig with the GTX 670 FTW to see if it will make a difference there too.
Thanks!!!
EDIT : The rig with my GTX 670 was already on 326.80 because I didn't upgraded the driver :biggrin:
This is why they were performing way more then the 770 :thumb:
lowfat
Grande Prairie, AB
I'll let you know tomorrow. I just finished watercooling it and about to see how well it scales w/ voltage.
EDIT: 260K w/ 1350MHz core. :thumb:
