LGA 2011
matari
Last year, I was convinced to wait for Ivy Bridge (IB). Well, IB is still a good six months away, and I am bored with my i7 920. LGA 2011 was just released, and I am considering the platform. I know the price is over the top, but it is going to be the same for every Intell enthusest platform.
If I decide to go with LGA 2011, what board? Keep in mind that I plan to H20 everything. The Asus RIV Extreme is an interesting board, and it looks fun to H20 cool (not). I really hate heat pipe designed heatsinks and I am burned out of Red/black/white color theme builds. I like the orange/black theme of the GA-X79-UD7, but can't seem to find any relavent reviews. I will more than likely use this project for folding. In closing, I am not 100% sold on LGA 2011, and if so what board would be great for H2O?
Eldonko
Calgary, AB
Not sure one board is better than any other for H20. The RIVE is handy because if you have a 1366 waterblock it will fit while some other may need a new block or mounting. They added a second backplate for those with 1366 coolers. Cant really comment on which board is the best at this point because nothing is even avail yet.
matari
If I recall coreectly, EK has a mount system that will adpapt to the current LGA mount system. Wonder if it is possible to use other coolers with it.
matsta31
Montreal
You might want to revise your folding goals with the Big adv changes... Starting in Jan 2012 you need 16 cores to Big Adv.
matari
Maybe I will change my goals; not interested in a dual CPU setup. I have the CPU 370, but to using it do to the thin layer of plating on the micro channels. I am going for silence, so I would to H2O the mother board. However, Those large heat pipe heatsinks, makes me cringe
lastsplash
Kenora, ON
For those interested, the XSPC Rasa M3 screws will fit through the M4 holes on LGA2011 and you can use a 1156 backplate to secure the block. A permanent solution will be released shortly.
From Dazhong at XSPC
