Jokester
So back in 2011 I left watercooling since I was working away from home from long periods of time. Since then I have returned to working closer to home. Then EK came out with the predator, I thought it looked like a great and quick way to get back under water. Unfortunately they seem to have a few kinks to work out. and so after a second failure I decided to go back to a custom loop :thumb:
Huge thanks to Dazmode for ultra fast shipping. :shok: I decided to do this last Sunday and had majority of the parts I needed by Wednesday :biggrin:
So onward with a water build. I should have taken more pictures of the parts as they came but I forgot!
Had to build a custom little bracket to mount the res/pump combo to the rear fan, only because that is where I wanted it to go. (Killkenny Required)
Darkside branded Heatkiller IV CPU block. Easy to install. Do wish they would just include a backplate with it though.
The Darkside LP360 is a pretty nice radiator, there seem to be a difference in distance from the fins to the outside that varied, so not the most precise build. But when I flushed it out, hardly any flux came out. Using three Gentle Typhoon Fans AP-60s. Other isse was I couldn't mount them to pull air in as some how they are catching on part of the radiators housing which causes the blades to rub. Unfortunate but the other way will have to do.
I realized pretty quickly once I mounted my pump/res that I was in desperate need of some angle fittings. Thankfully Dazmode was able to ship my order out so they arrived yesterday.
With the fittings I was able to a quick setup and leak testing:
