lol answer this
Rapid-X
Ajax
is there anything on the market that can be placed in the ddr2 slot and make it be able to hold 2 ram sticks like ...
lets say u have 2 ddr2 slots can u get sumthing that turns 2 into 4?? cause my board supoorts up to 16gigs of ram but only 2 slots im lost
sswilson
Moncton NB
Heh......
The chipset supports that amount of ram, but the board doesn't.
I'm not sure you can buy 2X8 Gig kits, and I absolutely know for sure that if you could, I wouldn't want to have to pay for it!!!!! :)
Gav
Administrator
Folding Team
Canada
What do you need that much ram for?
XP doesn't support 4gb's nor does Vista 32-bit. You need to look @ a 64-bit version on Vista before you can start getting any benefit out of 4gb's of ram.
If you only have 2 slots I would just buy a 2x1gb dual channel set and you should be pretty much good to go.
You also take a small performance hit when installing more than 2 sticks of ram, let alone compatibility issues trying to run 4 sticks together.
Rapid-X
Ajax
thnaks HWC
Windows XP Professional and Windows Server 2003 Memory Support. The maximum amount of memory that can be supported on Windows XP Professional and Windows Server 2003 is also 4 GB.
from Memory Support and Windows Operating Systems
jsut wanted to say thanks didnt think about capadability i jsut want to go fast. i have 2 sticks of 533mhx ddr2 pc 4200 installed on the board jsut waiting for the processor case and psu and im set
