Yes you can.. open FF, go to Bookmarks, Organize bookmarks.. that opens another window. From there I just select All Bookmarks from the menu on the left side, selected all of the options that appear on the right side of the window. Then there is drop down button for Import and Backup, just select export HTML and save it somewhere.
In IE, you could import bookmarks with an html file, and so does FF, so there should be a way in Chrome to import bookmarks through an html file.
On topic: that happened to me before, never for ncix though, that's really lol! .. I usually just ask the page to bypass really, not sure why it does that.
Google is your best friend though, try searching sure you'll get something.
