looking for a SFF case with four external bays for hot swap drives.
Mr. Friendly
British Columbia
got a project that needs a SFF PC for transport in a Pelican case that has four external drive bays that can be converted to being hot swap, if not already.
I'm hoping for something that is mITX, but suspect we'll have to go mATX to get this.
thanks! :)
moocow
Vancouver, BC
Can you expand on the four external drive bays bit? Do you require one 5.25 bay and convert it to hot swap 3.5 bay or multiple SSD bays or 4x 3.5 bays?
sswilson
Moncton NB
https://www.icydock.com/goods.php?id=244
This seems like a good start would only need a single 5.25 bay to mount this and it takes 4 drives.
Mix that with a low profile case (still micro not atx unfortunately) should be close to what your looking for
https://www.memoryexpress.com/Products/MX51924
Yeah, or if this is for a corporate environment... any small prebuilt corp desktop that has room for an optical drive will do. Those would fit fine in a deployment case.
moocow
Vancouver, BC
Apex MI 008 or Rosewill RS-MI-01, which looks the same with 1 expansion slot. SFX power supply included or you can toss it and replace it with a better unit. Cooler Master Elite 130 and Fractal Core 500 take an ATX PSU and come with 2 expansion slots so you could jam in a RAID card if you want. Icy Dock MB324SP-B is what you're looking at or something similar. 4x 2.5 inch hot swap cage for 5.25 inch bay. Aliexpress may have cheaper alternatives.
https://www.icydock.com/goods.php?id=196
