Want to Buy Looking for a simple 2 pin S/PDIF cable...!
Synth
Ottawa-Hull
Yup, the kind you connect your nVidia vga card to your soundcard to get audio over hdmi/dvi-d ... All 3 of my cards did not have the cable included in the box...
Anyone have a spare one, or know of a canadian etailer that sells them cheap online?
Cheers
Synth
Ottawa-Hull
Dude, seriously, you'd be a life saver !!
Before you commit though, could you check to see if the said cable fits on one of your 9800GTXs... ? I definitely wouldn't want you to go through all the trouble if the cable doesn't fit in the video card connectors...
But seriously, thanks man. Let me know if it fits, and I'll PM you my address.
:thumb:
Realityshift
Fort McMurray, AB
It came with the 9800GTX =D so I know it fits, plus ive used it and it works I just dont need to connect to my TV any more so I dont have use for it. PM me with your address and ill ship it to you tomorrow =)
EDIT: Can take a picture if you need to make sure but Im 100% sure its what you need ;)
