Low GPU usage
Lamb
Montreal, QC
I've been monitoring my PPD for the night and it seems the PPD from my GPU's keep going down the drain, what mostly worries me is my GPU usage : GPU 1 is @ 50~55%, GPU is @ 100%, how come my first GPU isnt @ 100% like the 2nd one? They're both working on P10101's , 2nd GPU = ~7600PPD, 1st GPU = ~4300PPD...seems abnormal!
Is there a way to make sure GPU's load will stay in the high 90's to 100%???
The clients are set to use 100%, priority is at realtime...and I'm mostly clueless on what is actually happening :doh:
EDIT : 1st GPU load went up all of a sudden...~90%
geokilla
Toronto
GPU Usage tracking does not work well with [email protected]
However as you said, your PPDs are abnormal. Try resetting the 1st GPU client. Are you running the latest drivers and Fah client and core versions?
Lamb
Montreal, QC
Everything is the latest (195.62, 6.23, 1.31)
But I think I got my answer >>> something was unstable, just had a BSOD.
I'm guessing my GPU's overclock was a little too high
