Thanks for that! Looks like they are coming up temp unavailable now... and when I follow the RFD links I am getting Intel versions, not AMD...?I know you said there probably wasn't any room to up the budget, but this looks like a smoking hot deal @ $680 + tax....
[Lenovo Canada] HOT - Thinkbook 14 and 15 AMD - 1080p IPS, Ryzen 4700u, 8GB Ram, 512GB SSD - $679 - RedFlagDeals.com Forums
Password is GoldWorkPerks2020 FAQ - 2 RAM slots - one is soldered with existing 8GB stick, other is available and configurable with up to a 4/8/16/32Gforums.redflagdeals.com
Reporting out of stock, at least for the 14", when you get to checkout. Bummer.Thanks for that! Looks like they are coming up temp unavailable now... and when I follow the RFD links I am getting Intel versions, not AMD...?
EDIT: I think I might have found it by roaming around a bit more.
There's another person now I'm also looking for, bit higher budget, but that 15" version, I think, only has a TN panel. I know how we generally feel about TN monitors, but any opinion on them in laptops; should I consider that an automatic no-go?Ah well, pity.
If you're still shopping, it's well worth keeping an eye on RFD to see if any more deals show up.
