hero1
Nice stuff man. I am proud of you and the work you keep on doing to this mod. Keep it up:thumb:
I didn't notice before... did you frost the cylinder of your res?
Yes. It was heavily scratched from a system I did a few years ago. Was able to get rid of most just by heating the acrylic with a heat gun. The rest I got rid of by frosting it. There will be more frosted acrylic in the final version of the system as I am aware the single frosted piece looks out of place.
You need a lot of patience for acylic. At least if you want to do a good job. It is similar to sleeving in which you can't be afraid to toss the piece and start over if you make a mistake. If you make a bad bend there is almost no going back and fixing it.
