Completed lowfat's Big Lian Li.
Father Fuzzy
B.C.
i'm sure you will Dig did the cheap extension set
isnt as scary as the reverse lens adapter
lowfat
Grande Prairie, AB
ProGripped the backside of my sound card. I didn't like how all the silver solder points showed. Plus matte pcb > glossy. :whistle:
enaberif
Calgahree, AB
If you want a super macro just take two lenses and join them together. Its a bit tricky to do but I did it with a 70-300mm and a 18-55 kit lens and was very surprised at the macro level.
I would show you but I can't access the photos right now.
lowfat
Grande Prairie, AB
After I play around with the extension rigs I'll grab a coupler as well but you can easily damage the camera or the lens due to weight.
trodas
Czech republic
Replacing caps on such beautifully moded card won't be easy, tough... :)
I would first replace the caps and then apply the progrip spray :D
Purchased a 4770K... I delidded it.
Uhm, you what...? I see you removed the IHS, but delidded? What did you do to the poor CPU! :shok:
Yes I used the hammer & vice method again. You shouldn't be using plywood though as it is just too soft. Took way more hits than it should have. But it was all I had laying around.
I hope you did not used such brutal tools on gentle CPU, but on something else.
The IHS should come off easily, when you cut off the rubber around and THEN heat the IHS from bottom with small hobby torch to the melting point and thein it come off itself.
You using any other method?
And I would like to ask - where is picture of the core? I wonder how well you managed to lap the core of the CPU :biggrin:
lowfat
Grande Prairie, AB
Can't say I've ever had to recap well anything. If I had to I can easily peel this stuff off. Then reapply later on.
Yes i used a hammer and vice on my CPU. It is the proven way to pop off the IHS. Much less risky than using razor blades in my opinion.
Some pics of the Plasti-Dipped RevoDrive 3.
