Completed lowfat's Big Lian Li.
lowfat
Grande Prairie, AB
Did the PWM function actually work as well? I have 2 3.25 DDC pumps and they both list the PCB as 3.1 PWM and have the 4 solder pads
I was never able to test it on the Koolance ones because the solder point broke off. But I'd expect it to work.
lowfat
Grande Prairie, AB
Picture overload incoming!. Didn't do any work besides mount the blocks. And strip the logos off the rest of the ram.
Got the T-Balancer MiniNG in the mail yesterday. Not sure if I am going to use for this build or not. I already have a T-Balancer classic and BigNG. Doubt I'll need more than one.
Shadowmeph
Very nice , which system is that, I really like how the Black fitting make the blue sleeving on the lines stand out ugg makes me want to attempt another build but I would only embarrass myself hehe
lowfat
Grande Prairie, AB
Got a Scythe Himuro Mini in the mail. Completely useless for an SSD but it looks cool.
Mounted it w/ my pump in the case.
Drilled some holes. Putting the case together again. Decided to go w/ a slightly bigger reservoir. Changed things up a bit.
Shadowmeph
excellent work so far so how long after your finished are you sending it to me ;)
lowfat
Grande Prairie, AB
Was productive again today. Installed the motherboard tray again, now w/ a bunch of new tapped holes for cable management.
Installed the hardware in to the case. Plumbed and sleeved the loop. I am rather impressed how it turned out.
Kinda went overboard w/ the pics.
lowfat
Grande Prairie, AB
What is this cable for, the one on the left barb?
Water temperature sensor. The T-Balancer BigNG will control all the fans in my system based on water temp.
Very nice build so far. Your sleeving is great. Nice pics as well? What lens you using?
Lens is a kit 18-55 f3.5 IS. I'll upgrade glass one of these days hopefully.
