M.2 difference?
fightingfi
Looking at these not sure what the difference is if you can help me :)
MP44Q will be QLC instead of TLC i think for the non-q.
Read/write speeds and the MTBF will be slightly different. But for the "average gaming pc" probably never notice the difference between the two.
Although it's not likely to be too much of an issue for the average user at home, the TLC nand has a higher write tolerance and would likely last longer.
Looks like the price difference is only $15, so I would go with the TLC (MP44) drive.
QLC is fine for read-heavy applications, like a game drive, as it's only the write performance that's weak. If it was $50-100 cheaper, then I would ask what you plan to do with the drive.
