Per the title, make sure you only download Afterburner from 100% confirmed trusted sources.
https://www.techpowerup.com/301461/msi-afterburner-laced-with-malware-circulating-in-the-wild
"Cybersecurity researchers at Cyble identified such spoof websites that are visually identical to the MSI website; which host modified versions of the Afterburner software laced with malware. This malware can infect your PC with a multitude of bad stuff, including cryptojacking (using your PC's system resources to mine cryptocurrency for the attacker); and data-theft. Cyble deconstructed the malware-laced Afterburner installer in a bid to identify its nature. Apparently it uses Monero XMR miner software to mine cryptocurrency. Apparently the attacker repackaged Afterburner into a custom installer that, in addition to installing Afterburner, fetches XMR miner from the Internet and infects Windows Explorer (explorer.exe) with a cryptojacking payload. The easiest way to avoid this is sticking to known sources such as the MSI website (www.msi.com); or known websites authorized to redistribute Afterburner. If infected, SFC (system file checker), coupled with Windows Defender or other popular antivirus software should help"
