MasterCase H500
fightingfi
Hi all, i have the following pc case.
MasterCase H500
I was wondering what is the biggest air cooler i can put in with the top 200mm case and keeping the side panel on. Also im worrired that it might hit or lean on the graphics card problems? thanks all!
fightingfi
I did thats why i bought the case , Now again how big of a cooler can i fit inside it ???
moocow
Vancouver, BC
The clearance part of the case spec only listed 1 value so I assume that's the height of the cooler in relation to the side panel and not the width in relation to the top of the case. At this point, your best is to look up the size of the cooler you have in mind and figure out how close does it reach to the top of the case. I recommend a small tape measure to do the work.
