Gallery Maximus Formula, i7 875k WaterCooled Build
bautisj
Active member
Scarborough, ON
SHOW OFF LOL. Well i finished my 1st WaterCooled Rig. Lemme know if there's still more to add.
Water Cooling
o CPU - Apogee XT
o FESER TFC XCHANGER 480mm radiator w/ 4x gentle typhoon 1850's. 2 25mm shrouds, 2 30mm shrouds made from gutted fans
o Pump - MPC655 Vario
o Reservoir - modified Tribal Overkill 8-port Acrylic
o Pimochill 1/2" ID LRT tubing
o 4x Feser 45-degree rotary fittings
o 4x Scythe Gentle Typhoon 1850 RPM fans
o 2x Scythe Slip Stream 800 RPM fans
o 1x Silverstone Air Penetrator fan
lowfat
Grande Prairie, AB
If you ever get bored of your Tagan/A+ let me know. I'll take it off you in a heartbeat.
You could work on some cable management but for a first water cooled rig it sure don't look to bad.
_dangtx_
mtl
looks nice. how do you cope with the window? :) and how is noise? pump vs fans vs cooling.
bautisj
Active member
Scarborough, ON
Noise? its not that noisy when the case is on. plus i can lower all the fan levels if im not using it. i can low it up to 8xx something. Forgot it, I'm used to the noise of the fans lol. Its been running for like 4days now x_x
Sure i'll let you know. I'm looking for a gaming laptop now trade to this beast >.> but if ever ill be parting this baby out. I'll be sure running to you. and if ever take the whole case with the water cooling shiz on it. :)
Cable management? I've done my best or maybe? there could be more to fix but im not really a pro. Its my 1st build. The bottum part used to be like a garbage. i tied all the PSU cables in to one.. and the other tie is the sata and inverter cables. Don't know how to fix it anymore lol. and there's this 1 audoe cable connected to the Supreme FX that's the best thing i could do ( running it low and connect it to the Sound Card lol )
bautisj
Active member
Scarborough, ON
cool. whats ppd on the beast like? :)
ppd? btw my temps right now are like 76F maybe its just because my room is cold. but normally it runs 79F.
Highest temp i got is 81-82F. Its basically pretty low instead of using fans. before i had a fan rig. it runs like 39-43ishC its like 5-6C low than fan cooling
Jackquelegs
Burnaby, BC
DAMN IT! :angry2:
Anywho, looks okay for an enermax powered build. Those cables will stand out no matter how hard you try to hide them.. :shok:
bautisj
Active member
Scarborough, ON
DAMN IT! :angry2:
LOL
As of experienced. It is True LOL.
Well, I did my best to hide them and make the cool :) Right? :)) :punk:
