memory dump error need help
QuickDeath
North Carolina U.S.A
so i finally build my new computer this is what i got
Intel Core i3 2100 Dual Core Processor:
Gigabyte GA-Z68A-D3H-B3
Corsair XMS3 8GB kit
ATI Radeon HD6870 1GB
750W Corsair Modular Power Supply
Seagate Barracuda 500GB 7200rpm main harddrive
but im running into a problem, after about 20 mins the system gets a blue screen with a memory dump error, i have tried removing the ram and booting and all at and even have done the memtest to test the ram but still no luck, u need some of your wisdom. this doesn't happen all the time but in a 24 hours period it has happened 6 times so far need your help lol
now it happened agion just surfing the web
bignick277
Right click my computer and click properties. Click the advanced tab. Click Startup and Recovery. Take the tick out of the box for Automatically restart and click ok. Next time you get the memory dump it won't restart the computer automatically. On that memory dump screen, it will tell you the cause of the memory dump. It can be an error (ie not less than or equal: which can point to memory) or it will list a file, which can indicate a driver issue. If you've already ran memtest and it's passing, there are any number of issues that can cause BSOD's. Write down the error your getting the next time it BSOD's so we can narrow down the possibilities.
You can also check event viewer in Control Panel -> Administrator Tools -> Event Viewer. Look through the logs and see if there's a listing for an event that corresponds with the time that the computer crashed. You often get quite a few errors and warnings during startup so it may not be first in the list. So take note of the time when you BSOD to make it easier to locate the log. If it's a BSOD and if there is a log, it will most likely be in the critical section.
Also what are your temps like? Are you overclocking your computer? When does it happen most often? Is it pretty typical that it's every 20 minutes or is it more random?
QuickDeath
no im not overclocking it, its all stock lol. its more random then anything as far as when it crashed and its not passing the memtest now i got to fails last night as i ran the test all night +5 hours or so,and as far as temps go its right on the money bc im not taxing the system just watching a movie lol.
i have been doing some reading and i think its a ram issues bc alot of people had a problem with the ram a got so it will be going back tomorrow
QuickDeath
this is what i am running its corsair ddr3 ram
nope none are overclocked the times isTimings: 9-9-9-24
Voltage: 1.65 V
and it just crashed again watching a video lol
Soultribunal
Mississauga
To help somewhat pin it down, download 'Whocrashed' as that can read the crashdump files and it can help us a bit.
Also, if you running Win7 do a few passes of Windows memory diagnostic (or make a disk with Memtest on it and run it to test your RAM).
Most of the time, its a RAM thing.
-ST
QuickDeath
[FONT=Segoe UI, Arial]<hr> Welcome to WhoCrashed (HOME EDITION) v 3.03 <hr> [/FONT]
[FONT=Segoe UI, Arial]This program checks for drivers which have been crashing your computer. If your computer has displayed a blue screen of death, suddenly rebooted or shut down then this program will help you find the root cause and possibly a solution.
Whenever a computer suddenly reboots without displaying any notice or blue screen of death, the first thing that is often thought about is a hardware failure. In reality, on Windows most crashes are caused by malfunctioning device drivers and kernel modules. In case of a kernel error, many computers do not show a blue screen unless they are configured for this. Instead these systems suddenly reboot without any notice.
This program will analyze your crash dumps with the single click of a button. It will tell you what drivers are likely to be responsible for crashing your computer. If will report a conclusion which offers suggestions on how to proceed in any situation while the analysis report will display internet links which will help you further troubleshoot any detected problems.
[/FONT]
[FONT=Segoe UI, Arial]To obtain technical support visit www.resplendence.com/support
[/FONT][FONT=Segoe UI, Arial]Click here to check if you have the latest version or if an update is available.
[/FONT][FONT=Segoe UI, Arial]Just click the Analyze button for a comprehensible report ...
[/FONT][FONT=Segoe UI, Arial] <hr> Home Edition Notice <hr> [/FONT]
[FONT=Segoe UI, Arial]This version of WhoCrashed is free for use at home only. If you would like to use this software at work or in a commercial environment you should get the professional edition of WhoCrashed which also allows analysis of crashdumps on remote drives and computers on the network and offers a range of additional features.
Click here for more information on the professional edition.
Click here to buy the the professional edition of WhoCrashed.
[/FONT]
[FONT=Segoe UI, Arial] <hr> System Information (local) <hr> [/FONT]
[FONT=Segoe UI, Arial]computer name: WHITEOUT-PC
windows version: Windows 7 Service Pack 1, 6.1, build: 7601
windows dir: C:\Windows
CPU: GenuineIntel Intel(R) Core(TM) i3-2100 CPU @ 3.10GHz Intel586, level: 6
4 logical processors, active mask: 15
RAM: 8503017472 total
VM: 2147352576, free: 1981517824
[/FONT]
[FONT=Segoe UI, Arial] <hr> Crash Dump Analysis <hr> [/FONT]
[FONT=Segoe UI, Arial]Crash dump directory: C:\Windows\Minidump[/FONT]
[FONT=Segoe UI, Arial][FONT=Segoe UI, Arial]Crash dumps are enabled on your computer.
[/FONT]
[/FONT]
[FONT=Segoe UI, Arial]On Mon 2/6/2012 3:43:54 AM GMT your computer crashed
crash dump file: C:\Windows\Minidump\020512-12105-01.dmp
This was probably caused by the following module: [FONT=Segoe UI, Arial]ntoskrnl.exe[/FONT] (nt+0x7CC40)
Bugcheck code: 0x1A (0x8884, 0xFFFFFA800322E4E0, 0xFFFFFA8003249510, 0x105)
Error: [FONT=Segoe UI, Arial]MEMORY_MANAGEMENT[/FONT]
file path: C:\Windows\system32\ntoskrnl.exe
product: [FONT=Segoe UI, Arial]Microsoft® Windows® Operating System[/FONT]
company: [FONT=Segoe UI, Arial]Microsoft Corporation[/FONT]
description: NT Kernel & System
Bug check description: This indicates that a severe memory management error occurred.
This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver which cannot be identified at this time.
[/FONT]
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: [FONT=Segoe UI, Arial]aswsnx.sys[/FONT] (aswSnx+0x1C2C4)
file path: C:\Windows\system32\drivers\aswsnx.sys
product: [FONT=Segoe UI, Arial]avast! Antivirus System[/FONT]
company: [FONT=Segoe UI, Arial]AVAST Software[/FONT]
description: avast! Virtualization Driver
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: aswsnx.sys (avast! Virtualization Driver, AVAST Software).
Google query: [FONT=Segoe UI, Arial]aswsnx.sys AVAST Software MEMORY_MANAGEMENT[/FONT]
[/FONT]
[FONT=Segoe UI, Arial] <hr> Conclusion <hr> [/FONT]
[FONT=Segoe UI, Arial]2 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
[FONT=Segoe UI, Arial]aswsnx.sys (avast! Virtualization Driver, AVAST Software)[/FONT]
If no updates for these drivers are available, try searching with Google on the names of these drivers in combination the errors that have been reported for these drivers and include the brand and model name of your computer as well in the query. This often yields interesting results from discussions from users who have been experiencing similar problems.
Read the topic general suggestions for troubleshooting system crashes for more information.
Note that it's not always possible to state with certainty whether a reported driver is actually responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
well running this program it says the antivirus i run is the cause
[/FONT]
