Mini Murder Box V6
Shadowarez
Folding Team
Arctic Canada
Hi all build is imminently waiting a new 5900x and maybe a slim 90m fan.
Specs if the Build
1. AMD Ryzen 9 5900x
2. Asus Strix -i Gaming x570 itx
3. Gskill 4000 MHz CL18 32GB 2x16GB
4. Cosriar 750P
5. Ncase M1 V6
6. Asus 1060 6GB Duel (White)
7. Noctua NH-L12S
8. Nidec Servo 120mm Gentle Typhoon AP-15(Side Panel)
9. Noctua NF-A12x25 (cpu fan)
10. Noctua NF-A12x15 X2 (Bottom)
11. Samsung 860 Pro 4TB (Sata)
Shadowarez
Folding Team
Arctic Canada
Currently i couldnt fit even the slim 120m under the heatsink so i had to improvise and pull from the top to exhaust but decided to put a better fan on it hence the NF-A12x25 it is Exhausting air out to the Nidec Gentle Typhoons which also exhaust out. once the 5900x arrives im going to do some testing to see if its better exhausting or all intake and blow air over the cpu and board.
i have the corsair commander set to balanced for all fans the ones on bottom are set to exhaust as well.
Shadowarez
Folding Team
Arctic Canada
ill add some pics for testing got the stress tests going prime 95/aida did some torture tests surprisingly temps were steady at 68-70c :eek:banana
