Too much money for bitspower fittings
But I'm glad I purchased them!
Cheap sleeving. Free from my LCD monitors!
Some more tubing going in...
7V trick on my pump for silence (since it's one block one rad...)
Filling! Also a quick 10 min leak test while I bleed the air.
Two leaks. One at the BP crystal T... tighten it with pliers. Second was the FAR CORNER of the radiator. I have to pull out the vid card, and take off the side panel to get to it (barely enough slack on the tubing), and reach in with needlenose pliers to tighten it up.
When leak testing/bleeding I ran the pump at 12V. Tested it out, but decided to reduce it back down to 7V for noise and to compare temps... but the stupid pin broke!
Quick solder job later, and BAM, stupid messy cram packed build:
