Mining with a GTX 1080 Ti...
sherwind2010
Canada, BC
60 MH/s from a free miner! :clap: ccminer-x64-2.2 DOWNLOAD!
Arinoth
Halifax
Switching to the new 2.2 ccminer seems to have increased my output from 49 MH/s to 52/53 MH/s on my 1080 Ti running stock.
It seems the 32 bit and 64 bit at times can change who does the 53 MH/s and who doesn't.
It also boosted my GTX 980 from 20 to 21 MH/s
sherwind2010
Canada, BC
I think the 32-bit works better for 1060 & 1070. I don't have them so I really don't know.
BTW I'm running my 1080 Ti's at -i 27
Arinoth
Halifax
I thought the maximum intensity was 23? I could be wrong and haven't dug that much into it. It appears overnight it's settled better on the 32 bit at 56 MH/s running stock at intensity 21.
sherwind2010
Canada, BC
Nope, I have mine set at intensity 27... higher than intensity 27.2 won't work. 27.1 works. It just above 60 MH/s. I wonder if I'd get more MH/s if they were water cooled with a full cover block?
I could mess around with it to maybe get more efficiency for the same 60 MH/s, here are my setting now.
PT set to 127%
Core +150
Mem -502
Voltage set at 75%
Coach
Morden MB
I am having issues getting my new FTW3 much over Sols/s. With 100% power, +34 core and +500 mem I see it run about 1960 mhz and get just over 700 Sols/s. Shouldn't I be seeing 800+ Sols/s with equihash?
sherwind2010
Canada, BC
I had PT set at 127%... Core was set at 80+.... Mem was set at 700+... Had fans on full speed.
Coach
Morden MB
Thank you for the reply.
My FTW3 has the limit of 117% for power. Any idea why that would be? Also who made your vram? My GDDR5x is Micron.
sherwind2010
Canada, BC
Try it at 117% if it still doesn't get 800 Sol turn off your PC and switch the switch on the GPU board to slave. It should be by the 8 pins power. I would think mine is made by Micron too.
Coach
Morden MB
Thanks I will try the other bios. I think your GPU clocks better in general but I thought equihash was a memory based algorithm.
