mobile computing forum...
Marzipan
Prince Rupert, British Columbia, Canuckistan
Good Idea!
of course! they're the only kind I have!!! :clap:
it came to me because while I will have a desktop as a file server soon (I hope), I'm moving over to mobile platforms. I was fortunate enough to be one of those who got the Futureshop special for the Acer 5920-6273 for $799. if you don't know what I'm talking about, it's a 15.4" Gemstone design...T5250@1.5ghz|2GB DDR2-667|250GB Hitachi 5400RPM HDD|HD DVD ROM/DVD Burner|8600M GT 512MB DDR2 and Vista Home Premium 32bit. all that for $799...and what's awesome is the 5920G line is totally upgradeable...minus a few things.
the bottom of this thing has a panel that covers about 75% of the bottom that can be removed via 9 screws that exposes almost everything. CPU, HDD, Memory, GPU...not sure about wifi, but the contacts may even be open for Bluetooth to be installed (this is iffy tho). if I can find a 8700M GT MXM2 card, I could upgrade to it. currently I can upgrade to the T7700 Merom...tho with the Penryn, as long as it's a 35w TWP model, I can upgade that too. 35w TWP is what this laptop can do. :punk:
just have to get settled and start saving to upgrade my laptop! :biggrin:
quick question...why can't you put some sorta code down for the emoticons? you HAVE to choose which one from the emot panel...and why do we have so little choices? :dots:
G
Guest
Guest
While it might not be done ASAP I am sure one will be added.
Nice Lappy, I have a gemstone.
Smilies:biggrin::thumb: can be added @ least they work for me.
Marzipan
I look forward to it being added. I understand this is a busy time of year and everyone is distracted.
in any case, my question about emoticons is that they don't show up if you do the key codes...such as <_< = :blarg:; :( = :sad:; :D = :biggrin: ...but the key codes don't show the emots. you have to click the actual emot if you want it to show up. :ph34r:
MacJunky
Grande Cache, AB
Personally I like it this way. It allows me to shun graphical emoticons in favour of text ones.
Anyway, how hard is it to click on a little emoticon to add it? Well, for me it is hard because I have them turned off for my reply text input box thingy(reply text input box area thing set to basic or whatever it was) but I like having the option to use graphical and/or text emoticons.
Prof. Dr. Silver
Toronto, ON
Of course we need to see some pics buddy....Show us the gory insides!!:haha:
