Mobo and DVD
DSNB
Active member
Halifax [Hammonds Plains]
I am confused.
DVD roms are you play DVD right?
DVD RW or what ever, (DVD SATA SL or w/e it is ) can write on DVD right?
Do I need both? Or can I just settle it with DVD RW?
Another thing, how do I check if my mobo is PCIE 2.0?
My mobo is Asus P5N32-E SLI Socket 775
sswilson
Moncton NB
I am confused.
If the spec page for the motherboard doesn't specifically state that it's PCIe 2.0 then it's not.
As far as DVDRom Vice DVD RW goes.... you've got it right, but in all honesty, it's not worth saving $5 or $10 bucks to get a DVDRom.... somewhere down the line you're going to want to burn something to a DVD even if it's just for backup purposes.
DSNB
Active member
:doh: I don't have the box on me.
Anyways, so I can settle it with DVD DR right?
Whoah you are in NS too? =)
sswilson
Moncton NB
Unfortunately it looks like the ASUS page is down so I can't link to the spec page.... :(
Looking at another site that lists the motherboard specs here.... Asus P5N32-E SLI it doesn't look like it supports PCIe 2.0.
And yeah, go with a DVD RW. :)
DSNB
Active member
NVM XD it DOESNT supports 2.0 PCIE.
EDIT: Don't close this X_X. So I can't run my XFX 8800 GT Alpha dog? There was another thread how it couldn't run it properly since it didn't have 2.0 PCIE...
Thanks for the suggestion for DVD =)
sswilson
Moncton NB
It should still work fine, you just won't be getting the full benefit of the card.
