Mobo change - re-install OS?
GT7R
The universe
As a general rule with win 7 - do you guys think I should re-install after changing a mobo? (to a different model of course)
GT7R
The universe
I don't care about the data as much, just to save some time as I'm getting this scenario many times.
blaze_125
Ottawa
You don't need to re-install unless you're changing the mobo of a OEM system with an OS tied to the hardware.
trayton
Tillsonburg, Ontario
I usually see if it boots first and lets me do the usual things I do.. If no crashes (blue screens etc..) then I'll leave it for a while and format when I have excess time (which doesnt happen often)
redline
Active member
Woodbridge/GTA
Yeah, Windows 7 should be able to handle it. You might want to uninstall drivers before making the swap. You could also use something like Acronis Universal Restore.
Pabz0r545
Edmonton, AB
I did the p67 to z68 with no problems but I just upgraded my brothers computer from an x58 platform to z77 and the swap did not go so well. We were unable to boot into windows after installing the new cpu/mobo/ram. I had to pull all the hardware out of his case and hook the old stuff back up to get the new drivers on before we installed the new hardware.
crazyea
Surrey, BC
What he said. I even ran mine for a month or two until it forced me to reactivate again.....
