moniter screen repair
KaptCrunch
Ontario
fixed a blinky viewsonic screen
working away after replacing all the caps on psu in LCD moniter cured the blinking, after moving stuff around some how i put a gough/ deep heavy scatch on mid center of screen
using girl friends clear nail polish (acrylic lacquer) to fill the crator and 600grit water paper with a old alu HS for flat surface
applied in thin layers with 5mins between till had a lump, let sit 6hrs then wet sanded it flat (note surface wetted)
up close you slightly notice the edge of nail polish but afar looks norm
mite also work on CRT
other use YouTube - NEW 2009 Meguiar's ScratchX 2.0 G10307
