Work in progress Mother Dark. Fractal Torrent.
Shadowarez
Folding Team
Arctic Canada
i want heat killer it not only sounds cool lol but they look far better then EK in my opinion. i just need to buy a nice chongus 420 rad and nice 480s for my rig. then all the fun lil bits but i think i'll test it on the intel test bench first which means 2 blocks lol.
lowfat
Grande Prairie, AB
The Barrow GPU blocks came w/ RGB strips. Came w/ a fan connector. Thinking they were maybe just 12V white I hooked it up to 12V. Nothing. Suspected I killed it. But generally you only kill the first diode.
Found removing them too difficult. End up just damaging the diode.
So I just created a jumper to skip it. Works.
Adding some 'underglow' strips. There are spots to install specific Fractal ones. But I'll just use my own.
aRGB controller after painting
Rear cabling so far. Finished off the front panel (power,reset,led. everything else removed), aRGB power in, 8-pin EPS.
