Please do not post any links until you have 3 posts as they will automatically be rejected to prevent SPAM. Many words are also blocked due to being used in SPAM Messages.
Thanks!
I am about to build my First computer and need help selecting a motherboard. i am going to the Quad Core zambezi gtx 550 ti SLi 8gb Ram Please help budget $150 USD thanks.
I don't know the circumstances, but are you stuck on that platform? There's not too many that would go for that processor. If you're an AMD fan, there better way to spend your money. If you're open to Intel, the 2500K is probably the sweet spot of price/performance now, but if your budget it tight and you're an AMD fan, then the Phenom IIs are a cheap way to get performance on a par (or better) with Bulldozer - the llano chips are probably better value as well - or for intel might consider the i3-2100?
I know you didn't ask about GPUs, but did you already buy the 550s?
990FX chipset. All of the major manufacturers have a version of it. I'm running an ASUS Sabertooth 990FX and can confirm that SLI now appears to be operating properly on it.
Next question would be.... why Zambezi, especially a quad? You'd get much better performance out of a quad PH II. A quad Zambezi is at best 2 1/2 real cores worth of performance.
personal picks i7 2600k, i7 2600, i5 2500k, i5 2500,
i3 560 ~ 4500mgz overclocked
{the i3 i3-2100 is locked and can't really be overclocked last i checked} or
