Motherboard swap issue
r0k0
Age
31
Gatineau, Quebec
Ok so i've done this a couple times with succes, it was almost done but i guess it failed
Swapped hardware, booted up fine in windows, installed the new drivers restarted and now it hangs on windows loading screen, it will not boot, wont repair and nothing else will work, any suggestion ?
I do not want to reformat for lots of reasons even if i did a backup lol
Skyllz
Ottawa
Is AHDC(or ADHC?) enabled or disabled in the bios? That was the issue when I did the same a while back.
ZZLEE
KANATA
Write down all your bios settings.
Flash newest BIOS.
Try all your old bios settings.
UFFI Bios gets Hacked by Windows. so helpfull I coudn't get into default bois and get in. SO Helpfull ! today also
47 x 100 yey :biggrin:
r0k0
Age
31
Gatineau, Quebec
All ottawa boys helping out, i cant find the adhc or ahdc
Zzlee i have everything to stock, nothing has been changed and i cant flash bios i have nothing to get a new bios :p
enaberif
Calgahree, AB
Its AHCI and unless you were running Windows XP previously its a setting that won't matter.
Do your basic troubleshooting; unplug everything that isn't needed to make the system work, check the standoffs and check the back plate.
r0k0
Age
31
Gatineau, Quebec
Reinstalling windows... Everything worked fine until i rebooted for the nee chipset drivers
odis172
Ottawa, ON
Ima have to chime in here since i'm from Ottawa.. Stange you would have problems with the latest chipset drivers. If they arent working, I would grab the latest ones from the motherboard manufacture's site.
rjbarker
Courtenay, B.C
In most case a clean install of Windows is the best way to go when swapping Mobo's. Always ensure to have your Programs / Data stored on a different Drive, makes a clean install a lot less painful.
