Mounting arm - 49"
Cypher^64
Red Deer, AB
My current arm can't hold the Samsung 49", tighten the springs up as much as they can go and can't hold it vertically or the tilt.
This monitor weighs 11.6kg, what would be a good solid arm for it.
If it mounts through the desk that'd be a bonus, then I can keep the desk as close to the wall as I can, but one that clamps on the back is fine as well.
Any recommendations?
Lysrin
Nova Scotia
I use Vivo, but don't have anything as big as a 49". I have my 34" on one of their mounts. Well made for the price, however mine are not spring adjustable. You set it where you want and tighten it down, with the exception of turning side-to-side. That direction you can always move.
SugarJ
Folding Team
Langley, BC
There's a metal plate to keep you from doing exactly that, he said. 😤
