Mounting arm - 49"
Cypher^64
Red Deer, AB
I gave up on the idea of dual monitors. Just getting greedy for space.
The first mount from Amazon wouldn’t support the weight. Broke down and ordered the Ergotron HX in matte black
Mr. Friendly
British Columbia
if the bottom mount was fully moveable I would have grabbed it
it will, but not for a 49" display, that's a bit to much for it. officially it can stack up to two 27" displays. however...the weight limit per display is 22lbs. my two Dell U2415w are 18lbs once the stand's removed, so with the extra tall one, I expect it'll be kosher.
you could also do piece meal if you wanted to. if you check the spare parts section, you can buy the 39" stand alone and then choose a number of different VESA mounts that clamp to it. like one articulating and one fixed. :)
